Question about Relisys Computers & Internet
I have an old monitor P/N TL561-RU and I am trying to use it with a cctv camera and recorder.
How can I remove the message OUT OF RANGE
  • Relisys Master
  • 3,320 Answers
The signal strength or format of the signal from your playback device does not mesh with the monitor's capabilities.
As an example digital signals will not show on an analog monitor.
Posted on Mar 27, 2014
4 Suggested Answers
SOURCE: How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Posted on Jul 29, 2007
  • 17 Answers
SOURCE: out of rang vw193t
Pls temporarily install a older monitor then check the display sttings ,set it to the lowest resolution apply and then check whether its working on the old monitor.Then shut down and connect the new monitor and power on the monitor should work
Posted on Jan 24, 2009
  • 476 Answers
SOURCE: osd lock in my LCD
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
  1. Click START.
  2. Click SETTINGS.
  3. Click CONTROL PANEL.
  4. Double click DISPLAY.
  5. Click SETTINGS.
  6. Set the resolution SLIDE-BAR to 1680 by 1050.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
203-35.jpg Hope this helps ,
Rate me please,
Cheers Misterdj
Posted on Aug 12, 2009
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
Outdoor Digital Wireless 2 CCTV camera System 7" LCD monitor DVR Record to SD TF but recorded playback poor what can I do please I am 81
Try recording in a higher quality than standard and see 2hatcthe results are.some of those are low resolution cameras and you won't get a wonderful image out of them.
Jun 28, 2015 | OUTDOOR Home Security
Can the exsisting protacal be modified?
Good question. What camera? Most cameras cannot be modified. Some newer cameras are multiple protocols. Need more information.
Sep 25, 2014 | CCTV Camera Pros MON-LCD35P Test Monitor...
I have a sentient CCTV Hard drive recorder. Was working, but now shows no picture on the monitor. Power supply light on but does not work.
Unfortunately it is past DIY stage. Consult a service center.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 05, 2010 | Home Security
Osd lock in my LCD
  1. Click START.
  2. Click SETTINGS.
  5. Click SETTINGS.
External Controls
Rate me please,
Cheers Misterdj
Aug 12, 2009 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
We've got a church tv camera that records picture so that predominantly neon green and pink appear on the recordings. The neon almost looks like fire. What should we be looking at besides the normal...
You leave out too much information. What kind of camera (CCTV, IR, BW/Color, handheld, web cam, etc). Name/Brand/Model ? What are you trying to do? Security? Film your service? Broadcast via internet? What kind of monitor are you using and how do you know it is a known good monitor?
Your information is too vague so I can only give you a vague, potential answer;
potential is high that the actual chip lense itself is at fault, potential fault within chroma/color circuitry or if it is an older camera, out of adjustment and if very old, tube is no longer viable.
Additional thoughts: EMI shield malfunction on the PCB (highly rare).
Sep 29, 2008 | Cameras
How to record from a cctv camera to a digital tv recoder
You can't do this at all. It will only record from its own freeview tuners.
May 05, 2008 | Televison & Video
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Computers & Internet Logo
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
