Question about Mitsubishi WD-65731 65" HDTV
No sound after my son plugged in something that he was using to listen to music into to use the speaker system from the tv, there is no sound
    Scholar:
  • 195 Answers
Make sure the speakers have not been turned off in the menu. If not--the amp chip in the Tv could have been killed. Along with a fuse or resistor in line with it. Not usually a hard problem to fix.
Posted on May 08, 2014
Can i add Cyber Acoustics 2.1 3-Piece Computer Speaker System with Subwoofer to my tv using roku3?
You can't use 2 different speaker systems connected to one device output.
You could connect the CA speakers connected to your Roku and improve your TV sound. You could also use your microlab speakers connected to your computer to augment your computer based audio.
Apr 08, 2014 | Audio Players & Recorders
Protect message
If you are using AV cables from your TV for movies and a different hookup for the X-Box would explain that the relay for the sound inside your unit may have blown from being overloaded or faulty. Should be an easy fix at a trusted electronic service place.I am not sure if your system has a manual reset button underneath or on back, but you could look for a tiny hole with reset on it or a red button. It may save you a trip to the doc.
Nov 11, 2007 | Marantz SR4500 Receiver
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Jan 08, 2013 | Audio Players & Recorders
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
moz-screenshot.pngmoz-screenshot-1.pngYour front panel audio / microphone connector has an AC97 connector inside which looks like this:
http://www.digitaldingus.com/reviews/silverstone/fp34/fp34-usb-ac97.jpg
It is probably plugged into the motherboard somewhere. Try plugging it into the soundcard directly if it is in the motherboard. Or vice versa if it is plugged into the soundcard.
-Alex
May 06, 2011 | Computers & Internet
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Acer aspire desk top t180 has no sound
Sounds like he forgot to plug back in the sound cable when he took his iPod out. Simple fix for this. Pull out the desktop box (computer) and find what should be a green sound cable and plug it into a green port in the back of your computer. If your having trouble as to what it looks like, get your son to identify what he took out of your desktop to listen to his iPod and plug it back in. Also check that your speakers are turned on and are up on the speakers and on your desktop, which you can find in the bottom right hand corner near your desktop clock. The icon looks like a speaker and just click on it once and make sure its up all the way and not muted. Let me know if this works or not
Hope This Helps
Nov 19, 2008 | Acer Aspire™ T180 PC Desktop
Sony erricson k800 cant recieve files via bluetooth although i can send via bluetooth.
Did you turn the bluetooth on and put the phone in discovery mode before attempting to receive something via bluetooth?
May 01, 2008 | Cell Phones
Mitsubishi WD-65731 65" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
