Question about Huawei Cell Phones
When i go to setting and tap wifi to turn it on it says turning on for bout 30 seconds then says error.
Wifi error when turning on
    Problem Solver:
  • 9 Answers
Tried to return to factory mode? If that doesn't work I would return it to the store and replace or repair.
Posted on Mar 26, 2014
Alcatel one touch pop icon. My wifi works fine,but when I turn off the wifi and turn on the data connection my phone says no internet connection, and yes I do have data. Help Please.
Sounds like maybe your data needs to be rebooted. On your phone turn off the WiFi and data, then turn your phone off for 30 seconds. When you turn your phone back on wait an additional 30 seconds before you turn data back on. After the 30 seconds test your data and see if it's working. If still not working you could have an app or something causing your phones rams to be high. And even then just reboot your phone and it should work.
Hope this is helpful
Ellen
Apr 17, 2017 | Alcatel Cell Phones
How do I fix a problem with my Galaxy 3 Samsung Tablet? I was always able to access the same internet WiFi I use for this computer, but for some reason it will not let me get on the internet at all.
First of all, make sure that airplane mode is not on.
Now, go to settings, and tap WiFi or wireless, it should open another window, in this window you should be able to see your internet SSID (router). Tap it and then tap forget.
Turn off wifi for some 10 seconds, turn it back on.
Wait until the internet that you want to connect to shows up.
Choose it and input the passcode, if any.
You should be good to go.
Dec 12, 2014 | Samsung Cell Phones
How to save battery power on kyocera hydro
Cell phones are drained by running background apps, LCD brightness etc. Here are a few tips to help you. Most importantly, batteries do loose their strength (even when fully charged). I would possibly replace the battery every 2-3 years with a name brand battery, not a generic. Also keep in mind, when your phone is charged at 100%..unplug it. Tips to save battery life To save and extend battery life, follow these steps:
Lower screen brightness and timeout duration
  1. From any home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Battery.
  4. Tap Brightness.
  5. Touch and slide the Brightness slider left to decrease the brightness setting.
  6. Tap OK.
  7. Tap Screen timeout.
  8. Select one of the following options:
  9. 15 seconds
  10. 30 seconds
Turn off Wi-Fi, Bluetooth, GPS, Portable Wi-Fi Hotspot
  2. Tap Settings.
  3. Tap Tethering & Networks.
  4. Tap Mobile HotSpot.
  5. Clear the Mobile HotSpot check box.
  6. Tap the Back key.
  7. Tap the Back key again to return to the 'Settings' menu.
  8. Scroll down to 'PERSONAL,' and then tap Location access.
  9. Clear the GPS satellites check box.
  10. Touch the Status bar and slide it down.
  11. Tap Wi-Fi to turn off.
  12. Tap Bluetoothto turn off.
Change application sync settings
  1. From any Home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'PERSONAL,' and then tap Accounts & sync.
  4. Clear the Auto-sync data check box.
  5. To reduce sync settings for individual applications, select the desired application.
Turn off background data
  2. Tap Settings.
  3. Tap Mobile data.
  4. Tap the Menu key.
  5. Select the Restrict background data check box.
Minimize use of third party applications
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Apps.
  4. Select the application you want to edit.
  5. Tap Disable to turn off the application.
    Note: You can tap Uninstall instead to completely remove the application.
Toggle from 4G to 2G
  2. Tap Settings.
  4. Under 'NETWORK SETTINGS,' tap Mobile networks.
  5. Select or clear the Use only 2G networks check box.
Update to the latest software
  2. Tap Settings.
  3. Scroll down to 'SYSTEM,' and then tap About phone.
  4. Tap System updates.
  5. Tap Check now.
  6. Follow any additional prompts.
Set device to sleep when unused
  1. Press and then quickly release the Power key to set the screen to sleep mode.
  2. To activate the screen, press and then quickly release the Power key again.
Apr 24, 2014 | Boost Mobile Kyocera Hydro Smartphone
My samsung galaxy poket turning off if i use wifi?
  • Tap the Menu key and then tap Settings.
  • Tap the Wifi switch to On.
  • Tap Wifi (to the left of the Off/On switch).
  • A list of available networks will appear, tap the network you wish to connect to.
  • If prompted, enter the selected WiFi network's password, then tap Connect.
  • Your chosen network will now show Connected to let you know its all setup, also you will see the WiFi signal bar in the notifications panel at the top of your screen.
  • If it still turns off try different hot spots. That modle only gets G2 and G3 connections.
  • Terry
  • Mar 21, 2014 | Samsung Computers & Internet
    Can't connect mini iPad to my wifi my other iPad is connected
    Always a good idea to shut down and then turn back on (hold down both home button and power button until it turns all the way off. Wait a couple seconds, then press the power button to turn back on)
    Try wireless again.
    If nothing, then
    Obviously check and make sure wifi is on under settings.
    If still nothing,
    Try resetting your network connections:
    Settings > General, then tap Reset > Reset Network Settings
    If you can't see any wifi networks at all, you might have a bad wifi card in the iPad. Bring back to an apple store.
    Jan 31, 2013 | Tablets & eReaders
    Cant set up wifi on my new tablet
    To set up your WiFi network, tap the Menu Key > Settings > Wireless & networks > WiFi settings. If WiFi is not checked, tap WiFi to turn wireless on, and wait for your tablet to detect nearby networks. Tap the name of your network and enter a security password, if required.
    WiFi networks that are configured as private or closed do not display the network name on WiFi-enabled devices. To Join a closed or private network, tap Menu Key > Settings > Wireless & networks > enter the WiFi network name, security, and password.
    If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
    Dec 20, 2012 | Linksys WRT120N Router
    When i hibernate, my computer turns back on in 30 seconds/
    check that it is not set to 'wake on wifi', if so, turn this setting off
    Oct 19, 2012 | Dell Inspiron 1200 Notebook
    Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
    Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
    Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
    My Droid won't upload (download, whatever) or allow me to email a 30 second video that I have taken with my phone. When I try to upload to Youtube, it says "Waiting for Wifi". What's up?
    Follow the following process to setup your wifi :
    1)To enable Wi-Fi on your Motorola DROID you need to initiate the process by tapping the Menu key.
    2)Proceed by tapping the Settings icon
    3)Next you need to select and tap the Wireless & Settings option.
    4)Tap Wi-Fi to enable it.
    5)To connect to a network, tap Wi-Fi Settings
    6)You may then select the network you wish to connect with and tap the Network key field to enter your passkey
    7)Tap Done and Connect to finish the process
    Jul 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
    Cell Phones Logo
    42 people viewed this question
    Top Huawei Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Danny Kuhlmann
    Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
