Question about Xerox Phaser 6180N Laser Printer
Want to know life expectancy of the 6180
I'm trying to figure out whether to replace the fuser or replace the printer. What's the lifespan of the machine?
    Novelist:
  • 217 Answers
I've seen these printers do over 300,000 pages, and at that pagecount they'd be on their THIRD transfer belt and fuser.
Posted on Sep 24, 2015
  • 78 Answers
A new fuser should be a lot cheaper than a new printer
Posted on Mar 29, 2014
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: OUR PHASER 6180 PRINTER IS
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
Posted on May 16, 2011
  • 110 Answers
SOURCE: Transfer Life Low Error on Xerox Phaser 6180
That error is caused when your transfer roller is out of life.
The transfer roller should be in front of the machine when you open the front cover. It will look like film material it is held with two plastic locks one on the right and on the left .
They maybe be colored yellow or blue sometimes.
(800)367-4836 <-company sells refurb and brand new ones. hope this helps. They will also give you free tech support.
Posted on Dec 23, 2009
StevenC82
  • 160 Answers
SOURCE: my phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Posted on Dec 19, 2011
Cp 5525dn fuser error
Fuser needs to be replaced.
Part # RM1-6180-000CN
Open right door Fuser is at the top squeeze the 2 blue handle to release the fuser and pull straight out. Install new one by just sliding in place until it "clicks"
Jan 22, 2014 | HEWLETT-PACKARD CP5525dn Laser Card...
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its life...it will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Hp t1100 error 50.2
nstructions
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
How to turn off replace fuser on display on xerox 6180
The message is caused by the fuser having had 100,000 pages or so through it.
It will be pretty much worn out, and should be replaced.
The transfer belt also has a similar pagecount limited life, and also the pickup/separation/transport rollers would benefit from replacing (they can get 'flat spots' on them
Jan 31, 2012 | Xerox Phaser 6180N Laser Printer
I have a Ricoh Aficio SP C210sf multi-function machine. I am getting an error message that says "unable to print". The trouble shooting in the manual is a joke. I have opened up all of the...
Yes, that is the cause of your problem - the fuser has died of old age and must be replaced. Here it is
http://www.precisionroller.com/fuser-assemblies---units-for-ricoh-aficio-spc210sf/details_41630.html
it comes with fitting instructions.
Jul 16, 2011 | Office Equipment & Supplies
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
May 16, 2011 | Xerox Phaser 6180N Laser Printer
My phaser 6180 transfer life repalce soon what is
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
What is the expected life of the M20i, before things start to break down. ie: scanner head etc..
This is a very good machine. The self life for the machine depends on Xerox when they end the service life.
The Copy machine is like a car, as long as you keep up the repairs and replace the worn out parts, it will last for a long time.
What you have no control over is if the plastic starts to fall apart due to time. Especially in the main frames. Stress cracks on parts that cannot be replaced.
Otherwise it can go on for a very long time.
Good luck.
Nov 06, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Xerox Phaser 6180N Laser Printer Logo
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
