Question about Nordic Track NordicTrack Treadmill, A2550
Drive belt replacement - Nordic Track NordicTrack Treadmill, A2550
  • Brendan
    Brendan Mar 26, 2014
    I am attempting to replace my drive belt. I got the old one off but I can't seem to get the new one on.
  • Brendan
    My treadmill is an A2350 not a 2550
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Start by putting the new belt on the front roller and then put on the motor pulley bottom. its going to be tight so just try to start it and then roll the pulley around with ur hand until it gets on the pulley
Posted on Apr 13, 2014
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
Replace drive belt Bosch pbs7a
To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
on Feb 02, 2014 | Bosch Belt Sander Drive Belt For Pbs 7a,...
Belt replace instructions
The accessory drive belt is a serpentine type belt that is driven by the crankshaft pulley
The belt drives the A/C compressor , alternator , power steering pump and water pump . Belt tension is maintained by an automatic belt tensioner .
Removal:
1. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be removed from pulleys .
2. Remove accessory drive belt .
Installation:
NOTE: When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves.
1. Install the accessory drive belt around all the pulleys except for the alternator pulley.
2. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be installed on the alternator pulley .Release spring tension onto accessory drive belt .
Jul 23, 2014 | COMPASS 2008 AUTOMATIC REMOTE ONE WAY...
How do you reinstall the drive belt on a T6.3 treadmill?
  1. Remove the drive belt
  2. Loosen rear roller screws
  3. Remove the screw holding the front roller
  4. Slip out the roller
  5. Slip on drive belt
  6. Put back together in reverse order
Dec 29, 2013 | Nordic Track NordicTrack T6.3 Treadmill
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
My Sonata GL is at 105K; in the maintenance schedule it is recommended to replace the timing belt. 1) If this particular belt breaks what would be the damage? 2) How much leeway do I have, eg.:100 miles,...
Timing belts are typically only used on overhead camshaft engines. Timing belts are used to synchronize the crankshaft with the camshaft, similar to a timing chain on an overhead valve (pushrod) engine. Unlike a timing belt, a timing chain will normally last the life of the engine without needing service or replacement. Timing belts use raised teeth to mesh with sprockets to operate the valvetrain of an overhead camshaft engine.
Whenever a vehicle with an unknown service history comes into your repair facility or is recently purchased, here are some points that should be asked to help prevent costly engine damage:
* Does the owner know if, or when the belt was replaced-
* If the vehicle purchased is used, or the condition and mileage of the last timing belt replacement are unknown, it is recommended to inspect, replace or at least inform the owner that the vehicle is equipped with a timing belt.
* Note the mileage of the vehicle. The average replacement interval for a timing belt is approximately 60,000 miles (96,000 km).
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
Removal & Installation
1. Raise and support the vehicle.
2. Remove the engine splash shield.
3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
4. Remove the drive belt from the alternator.
5. Slowly release the drive belt tensioner.
6. Remove the drive belt from the accessory drive pulleys.
Fig. Accessory drive belt routing - 2.4L engines
To install:
1. Install the drive belt to the accessory drive pulley.
2. Rotate the drive belt tensioner clockwise.
3. Install the drive belt to the alternator.
4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
6. Install the engine splash shield.
7. Lower the vehicle.
Hope helps.
Dec 22, 2010 | 2005 Hyundai Sonata
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Replacing the tension belts on the reFord windstar 1998.
FOR COMPLETE Diagram Of this Procedure and Belt Routing Email Me@rejakwilsoon@aol.com and I will Send DETAILED PICTURE and Instructions
NOTE:
  • Minor cracks in the V-grooved portion of the serpentine drive belt are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
  • When installing drive belts on pulley, make sure that all V-grooves make proper contact with accessory pulleys.
Conditions requiring drive belt replacement are excessive wear, rib chunkout, severe glazing, frayed cords, etc. Replace any drive belt that exhibits any of these conditions.
REMOVAL
  1. Using a 15 mm socket or wrench attached on drive belt tensioner pulley bolt. Rotate drive belt tensioner clockwise to remove drive belt from pulleys. WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP.
INSTALLATION
  1. Install drive belt over all accessory pulleys (except drive belt tensioner).Rotate drive belt tensioner as described under Removal to install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys
Feb 10, 2009 | 1998 Ford Windstar
Nordic Track NordicTrack Treadmill, A2550 Logo
73 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
