Question about Pinnacle Dazzle Video Creator Platinum (230100037) Video Capture
Won't install, is it because it's a mac?
Do you need to buy different packages for a mac and a window? my disk won't install and there's no button to install it, it is because the package i got is made for windows? do i need to buy a separate package for mac? is there a difference between the pc package and the mac package is what i'm asking.
    President:
  • Pinnacle Master
  • 1,314 Answers
Yes; Mac programs will only work on Macs and likewise windows programs will only work on windows. They are two completely different operating systems and therefore the programs have to be written for each environment.
Posted on Jun 15, 2009
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
The utilitech 0144506 I have won't charge when plugged in. No display comes on.
Troubleshoot if timers do not work:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Buy another timer at Lowes and take defect back in new package.
Try plugging into different outlet.
Press reset button to restore functionality.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 24, 2013 | Hardware & Accessories
How do you unlock the hard drive. I used it on my pc and now it won't let me add anything to it on a mac.
The windows PCs and MACs have different file system. That's why your MAC cannot recognize your hard drive.
In this case, you need to reformat it. there are a couple of possible solutions:
1. you can reformat the drive into FAT32 which should be readable for both windows and mac.
1a. as soon as you reformat it into fat32, you can use the Disk Utility on the mac to make 2 partitions and format one in NTFS (windows) and the other one in HFS+ (MAC).
2. you can buy a sofware called MacDrive and use that.
OR
3. you can use MacFuse, which is a recently developed free software that lets your MAC read windows drives.
good luck.
Sep 23, 2011 | Toshiba 120GB USB 2.0 Portable External...
I need to format my HD325 click free for mac
I'm sure the OP no longer needs to format their Clickfree C1 HD325 for use on Mac OS X, but I'll answer this question for anyone else who may need a solution.
Before you begin, there are a few things that you should know about Clickfree C1 and Mac OS X compatibility:
-Most Clickfree devices are compatible with Mac OS X 10.5 or higher, but there are some Clickfree C1 devices that aren't compatible with Mac OS X. If your Clickfree C1 was manufactured prior to 2009: your Clickfree C1 won't be compatible with Mac OS X.
-Take a look at the label located underneath the Clickfree C1: if you see WD08xxXM (WD08 is what's important here, you can ignore the rest of the numbers/letters that follow), your Clickfree won't be Mac OS X compatible.
-Formatting the Clickfree C1 using HFS+ will prevent any Windows operating system from detecting the Clickfree correctly. Try formatting the Clickfree in NTFS from a Windows computer for compatibility with both Mac OS X and Windows.
Pre-requisites:
-A Mac using OS X version 10.5 or better
-Administrator rights
Try the following steps to format your Clickfree C1 for use on a Mac (note that this will erase the contents on your Clickfree C1):
a. Using your keyboard, press the option key + command key + spacebar at the same time; a finder window will appear
b. In the search field located at the top-right of the window, type: Disk Utility
c. Finder will perform a search, and will display the Disk Utility application icon; double-click on the Disk Utility. The Disk Utility application will start
d. Plug your Clickfree into USB, wait a few moments for the application to recognize the Clickfree
e. Click on Clickfree Backup Media from the left side of the Disk Utility window
f. Select the Erase tab
g. Click on the Volume Format drop-down, select: "Mac OS Extended (Journaled)"
h. In the Name field, type: CF_Storage
i. Click on the "Erase" button.
j. Once the erasing is complete, close the application
k. Unplug your Clickfree from USB
l. Plug your Clickfree back into USB
Sep 03, 2011 | ClickFree HD325 320 GB USB 2.0 Hard Drive
I put in the cd to install this program and I only see files and scripts nothing comes up and allows me to install the actual program. I tried it on my pc and it worked but I didn't install it into...
Sounds like you have a Windows exclusive CD. It will not work on Mac OS.
If you have a windows install disk, you can install Windows on your Macbook Pro using Boot Camp via the Boot Camp Assistant located in Applications/Utilities. This will require you to restart and select one desired system to boot up in order to use OS X or Windows.
Alternatively you could run Windows and Mac OS simultaneously with a program such as parallels.
Jul 21, 2011 | Computers & Internet
The switch to turn on the wireless connection doesn't function properly/won't turn on. Even if it has been restarted already.
Hi Kate.Wifi can be turned on Windows (or Mac) via settings as well. You don't have to use the button. In Windows go to Control Panel > Network and Internet > Network and Sharing center > Connect to network.
But you have to install drivers from your notebook manufacturer first. Should came with your notebook on CD disk.
Jun 12, 2011 | Acer Computers & Internet
I recently purchase a emac for my daughter, it's
Hi, unfortunately not every accessory that you can use for windows based pc's is good for Mac platform. This is why when you click on Autorun.exe the Mac won't install anything and won't work.
You should check if the device you want to use is Mac compatible. If you don't have the original package you should go to producers website and search for your device compatibility list.
If your device is not designed for Mac paltform you have to buy another device Mac compatible.
Let us know if you solved your problem
May 16, 2011 | Apple Computers & Internet
I initialized my harddrive to a mac and now it won`t be detected by my PC
You cannot "see" a hard drive that has been initialized for MacIntosh from within Windows. The two OSs are not interchangeable at the hardware level of the drive. You will need to format the drive for Windows in order to see it in Windows or buy some software to install on Windows that WILL let you see the Mac drive.
Jan 05, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Pinnacle Dazzle Video Creator Platinum (230100037) Video Capture Logo
259 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
