Question about Juki MO6714 Mechanical Sewing Machine
Bartack machines skipping
Ever time i sew
    Sergeant:
  • 333 Answers
Hello Keith, From the little information you stated, I can only take a stab at what might be wrong with your machine. I suggest you make sure the take up spring is working freely and properly.
Posted on Mar 27, 2014
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
10 reasons for skipped stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
What is bartack
Bartack is a wide zig-zag usually at the ends of a buttonhole to prevent the fabric from stretch or tearing under stress.
What is Bartack Stitch
Sew Mama Sew Blog Guest Tutorial Bar Tack Buttonholes
Dec 22, 2016 | Sewing Machines
Have a brother excedra e40. Its started running on after i stopped . it will either carry on going or bartack and snap the needle ???
the machine could have a timing problem, and possibly a short in it. be a good idea to have it checked
Mar 02, 2016 | Brother Sewing Machines
My Janome Memory Craft 5700 using the R buttonhole foot will only do a striaght line will not turn at top for bartack any suggestios?
Go to page 25 in your 5700 manual and read from the beginning about how to set the buttonhole foot up. Make sure you have followed all steps. There is a lever on the button hole foot that you pull down. If you have done everything correctly, then you may need to call a service tech at a sewing store and have it serviced. You can get a copy of the manual from Janome's website.
Hope you find the answer.
Aug 08, 2015 | Janome Sewing Machines
Needle does not reach bobbin to to pull bobbin thread on surface
Sewing machine needles are specific to each model. If the needles are not for your model they could be too short or too thick so that they don't sit in the shank correctly. Check your user manual or Mr Google could help.
Jan 26, 2014 | Brother LX-3125FS 14/35 Stitch Lightweight...
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
I can't find my instruction book. Can you please help me with the steps to make a buttonhole?
what kind of kenmore? Do you not have it right on your knobs? 1 bartack, two down, 3 bar tack, four back up.......
Mar 19, 2010 | Kenmore 15212 Mechanical Sewing Machine
Buttonhole
When a machine does an "automatic buttonhole the feed does not move for a few stitches and maay jam if there are too many stitches made in this position. Is it an automatic buttonhole or can you choose how many stitches for your bartack? You ask about 0.5 well that is halfway between 0 and 1 on the stitchlength and this is indeed the recommended setting for buttonholes. If you are doing a manual buttonhole set your machine to this for the sides and zero for the bartacks but you only need about 6-10 stitches on the bartack. Fininsh it off securely by setting to straight stitch and stitch length zero for about 4 stitches to lock the thread in.
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Juki MO6714 Mechanical Sewing Machine Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
