Question about BeckArnley 1991 Geo Tracker Fuel Filter
How do i change a fuel filter on a 1991 tracker
  • 191 Answers
Hi Phil,you can read this article,it showing that How to Replace Fuel Pump and Fuel Filter,hope it can help you.
Posted on May 08, 2014
91 geo tracker died while driving cant get it started again
when you crank it, do you smell fuel? if you do, you're getting fuel so try replacing the distributer cap and even the plugs. if no gas smell, the fuel filter needs changing or the fuel pump is bad.
Feb 27, 2014 | 1991 Geo Tracker
1991 tracker with a 1.6. has a miss when running. when up to speed and holding at a steady speed miss gets worse. drove for about an hour and started cutting out very bad lost speed,power. converter red...
Do a compression test of the engine. See if your valves are seating properly is what you'd be looking for in checking for low compression. It could be causing the miss. When you changed plugs, did any one plug stand out as being different in color or texture at its base? The constant miss might put black sooty deposits on the spark plug. Course you'd have to remember which cylinder that plug came from to help you locate the miss. I'm assuming you have throttle body injection?
Feb 21, 2013 | 1991 Geo Tracker
It will crank and run good for a little while then it will skip a few times then cut off, we've narrowed it down to fuel. It is firing but isn't getting fuel, not the fuel pump because it seems to...
hi u could have ablocked fuel filter try replacing it if u have and motor is carburetered check were fuel line fits onto carby theres often a fine gause filter inside the bango fitting hope this helps
Sep 13, 2011 | 1991 Geo Tracker
We can't get our 1991 GEO Tracker to start
I had this problem as well. The tracker had sat for 8 years and would only run off of starter fluid. I replaced the filter and fuel pump then I had no fire. Located under driver side dash in the fuse panel theres a fuse for coil. I don't remember which one, but, I am pretty sure it is a 10 amp fuse. Or just do like I did and replace any bad fuses. If that doesn't work it will be a relay located above that same fuse box.
Aug 01, 2010 | 1991 Geo Tracker
Locate n change a fuel filter on a 1991 geo tracker
In front of the fuel tank on the passenger side mounted to the frame in the fuel line, not in the tank. Go to Autozone.com and you can get simple instructions on how to replace it.
Mar 11, 2010 | 1991 Geo Tracker
1991 Geo Tracker only starts with starting fluid.
Check fuel filter on both vehicles...After that check fuel pressure ...Blocking off air flow to engine will change the fuel air mixture...air deprivation changes (lessens) air flow and fools engine into reading more fuel than is actually there. Mass air flow sensor should also be checked/cleaned if no results obtained by filter change if pressure is OK.
May 29, 2009 | 1991 Geo Tracker
Fuel pump relay
Fuel pump in back in the gas tank.
May 29, 2008 | 2003 Chevrolet Tracker
BeckArnley 1991 Geo Tracker Fuel Filter Logo
374 people viewed this question
Top BeckArnley Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a BeckArnley Hardware and Accessory Expert? Answer questions, earn points and help others
