Manual monroe calculator 3150
Manual
Settings
I bet your display is showing the correct ans, however your printer is printing incorrectly. Settings have nothing to do with your ans. You need your printer to be cleaned or have the printer replaced with a rebuilt unit. I can do this... 608-222-2484...
Oct 22, 2009 | Monroe 7130 Calculator
I CANNOT ADD OR SUBTRACT ON MY MONROE 2125 CALCULATOR, COULD YOU PLEASE SHOW ME HOW TO DO IT?
Maybe you blew a fuse...Does it turn on? Call me at 608-222-2484...Ask for Milt,,will help you over the phone..
Sep 01, 2009 | Monroe Classic Calculator
Monroe 7130 displays an "E" and I won't respond.
Even you turn off then turn on the calculator, the 'E' still there? As I know, when 'E' display, if any key is stuck (press the key and it never pop up), all other entries will be ignore, until u release the key stuck. And, please confirm the printer is not stuck.
Jul 13, 2009 | Monroe 7130 Calculator
MONROE 7130 LOCK UP WHEN I PRESS THE PAPER ADVANCE. ALSO LOCKS UP WHEN I ADD WITH THE PRINTER ON. A E COMES ON ON THE LEFT SIDE OF THE SCREEN ALSO.
We repaired many Monroe 7130...this could be logic problem..maybe something on the logic bd. ...coke , coffee, etc. etc. staple, paper clip.. but in all probably you may have a printer gone bad.. You can always shake your cal to see if you have dropped anything on the logic bd... but always turn your machine off before you do this...this problem has happened only once or twice..we would try a another printer unit and isolate if it was a logic or printer and go from there...good luck 608-222-2484
Apr 24, 2009 | Monroe 7130 Calculator
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Need users manuel
Call Monroe and ask them how you can get a manual. Otherwise Google to see if you can find any website that archives manuals has it for download
Oct 30, 2007 | Monroe 7140 Calculator
27 people viewed this question
jasbo
jasbo
