I have a neptune MAH-4000AWW washer, the door locked light does not eluminate, and the clothes do not get dried durning the spin cycle, it never reaches full spin speed. It just started with both these issues, so I'm wondering if they are related, and how to go about fixing them.
if you remove the back console, youll be able to see the "machine controlboard". appro. ha;f way down and favoring the left side of circuit board youll notice a small blue relay cover(MAYBE 3/8"X1/2" in size. well just above that relay cover you see a resistor that will be physically burnt out( a real noticable burn ring around it) if this is the case you need to replace the board as well as the "wax motor" within the latch assy.
My Maytag Neptune won't stay running. It did not finish a wash cycle and when I try to restart it on...
(More)
My Maytag Neptune won't stay running. It did not finish a wash cycle and when I try to restart it on a new cycle, the water comes on along with the ''ON'' light for about 3 seconds and then stops. Same thing on every other setting. Light comes on then off and water stops. When I try to use spin cycle, water starts to drain and then stops. drum never moves. How do I troubleshoot this? I have read about error codes but where do I find these? My unit is a MAH3000WW Series 31 with no display. Help!
My Maytag Neptune Washer will not spin. I took the back off and the fan belt is on. I pushed the...
(More)
My Maytag Neptune Washer will not spin. I took the back off and the fan belt is on. I pushed the spin button with the back off and it makes a noise but the tub will not spin. There appears to be a lot of water in the washer. Is the motor burned out? John...
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
