1987 Yamaha FZ 600 Logo
e
eddie o connor Posted on Mar 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to do oil change cant find suump plug any helpfull video
Need to do an oil change and cant find sump plug any hepful videos thank u
jimhr10
Level 2:
Sergeant:
  • Yamaha Expert 391 Answers
  • Posted on Apr 13, 2014
jimhr10
Yamaha Expert
Level 2:
Sergeant:
Answers
391
Questions
0
Helped
104537
Points
509
It's on the bottom of the engine at the lowest point. It may be an Allen plug of a square plug.
How do i change oil and filter in toyota estima
There are two ways of changing the oil, and both involve running the engine until hot first.
Firstly, don't forget to have the spares (this includes enough oil to fill the sump -- find this quantity in the vehicle's instruction-book --and filter) and the necessary tools (oil-filter remover belt or long, thick screwdriver, sump-plug key and bowl) to hand.
The first way is to put a bowl which will contain enough to hold the lubricant under the sump and carefully releasing the sump plug. Do wear plastic (not rubber, as these dissolve in oil) whilst you're doing this as used oil can be carcinogenic. Now (remember the engine is hot), carefully loosen the sump plug. Put the bowl underneath the sump and remove the sump plug. It is more important to avoid the boiling oil than to catch the sump plug, which can be fished out later, when cool. Once cool, remove the bowl and replace the sump plug.
The second way is to go to a garage which offers free oil changes (you only buy the oil) and they will put a tube down your dipstick aperture and vacuum the oil out. This is not as good as allowing the oil to drip through the sump drain hole.
Now remove the oil filter using the strap or by piercing the old filter with a screwdriver and using that as a lever and turning the filter anticlockwise.
Put a little oil on the seal of the new filter and screw this onto the seating by hand. DO NOT TIGHTEN BEYOND HAND-TIGHT.
Refill the sump with the manufacturer's recommended type and quantity of clean oil, though there may be a little residual oil in the engine, so do check before overfilling. Do not overfill.
Put a piece of sticky paper in the driver's door jamb with the date and mileage at which you changed the oil and filter.
Where is the oil sump plug on a peugeot 407 hdi?
under the engine, it scares me that you want to know this if you cant find the sump plug. You realise this engine needs a low ash diesel specific oil when you do an oil change right?
How to change the oil
You will need a sump plug removal tool.
On older vehicles, this was just with a wrench.
But it could be a special key, check the plug on the base of the sump.
Take keys from ignition (as you do not want to accidentally start an engine with no oil.
Open the oil filler cap, place a container under the vehicle (could be quite a few litres of oil to come out) and remove the sump plug.
Leave the vehicle to do this for a short while, until it all stops dripping out.
Now you would want to change the oil filter.
These are in different location, but you can get a filter wrench to wrap around to remove.
PRE FILL the new oil filter with clean oil before installing (This stops any air locks when you start the engine after the change)
Hand tighten the new oil filter, they do not need a great deal of torque to screw in place. so generally a good hand tighten is enough.
You may need a new washer for the sump plug (some oil filter kits come with this in the box)
Now that the new filter is on, and the sump plug is back on. Fill the engine with the correct amount and type of oil.
I do not know the exact amount you will need.
But it is better to fill a little at a time, check the dip stick for the correct level.
When you are at the correct level.
Run the engine for a few minutes at IDLE.
Stop the engine and check the oil level again.
You should be all good after this.
Also check again after a few miles, that the sump is not leaking, and that the oil filter is also not leaking.
Transmission oil change
I take it you are talking auto transmission. Un do the drain plug in the box sump or if you do not have one remove the sump. replace filter in the sump . replace the sump with a new gasket and refill the sump. IF there is nothing wrong with the transmission and you only want to change the oil the best practice is to take it to a auto transmission shop where they can change the oil with the engine running and this changes the oil in the torque converter as well giving you a complete oil change. IT is more expensive as more oil is used but it changes all the oil and not just a part of the system. If your are talking manual, then remove the drain plug in the bottom of the gear box and when all the oil is out replace the plug tightly and remove the filler plug in the side of the box. Add oil until it runs out of the filler hole and when it stops replace the filler plug tightly. Use the correct grade of oils in both cases.
Clearing oil change light 2010 ford fusion
I had to reset my oil change light on and found a video on youtube done by vehix411.com. This might be helpfull. Here is the video.
http://youtu.be/EBx6L0WTJ1o
Why does my self oil singer industrial 491 machine drip oil on the floor
Problem with sump or with sump screw? Or overly full?
I'm currently refubishing a Singer 491. To understand what sump and sump screw are, check out the YouTube channel of becauseimcrafty for their instruction on changing the oil. This demonstrates the large oli pan of a Singer industrial machine that is similar to yours as far as the oil "pan" or "sump" goes. TItle of their video is <<Industrial Sewing Machine l Changing the OIL>>.
Not sure if link allowed here: https://www.youtube.com/watch?v=yIF8npj-VLk
1helpful
1997 Mercedes Benz C280 - oil change
hello,sorry,i just read your comments,better to remove your sump guard,(be careful),to see the oil drain plug,
1helpful
Locating oil filter and sump plug for 323 mazda
dont worry about pulling the wrong plug but just look for the oil pan and there is your little plug that needs to come out!
BMW motorcycle maintenance
to change the oil you need to remove the sump plug, located on the underside of the sump. the plug is a bolt on the botom of the engine. once the bolt is removd, oil will drain out rapidly so have a container ready to catch the oil.once drained put the sump plug back in and refil with new oil.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
