Question about Peavey PV6 Mixer
What is the power supply number for peavey pv 6
Primary side board number u22 power ic
    Top Expert:
  • Peavey Master
  • 3,107 Answers
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Posted on Jan 20, 2015
  • 17 Answers
SOURCE: manual for a pv 2000 amp
peavey manuals are available from www.peavey.com
Posted on Feb 02, 2009
  • 4234 Answers
SOURCE: i need a solution to repair peavey pv 2000 power amplifier.
Your best bet is to request a service manual from Peavey itself. These are usually available for around $20 or so. Call Peavey and ask for the service parts department and make your request there. They are very helpful and should be able to assist you.
Dan
Posted on Jul 11, 2010
  • 5603 Answers
SOURCE: i have Peavey Pv 2600
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Posted on Aug 29, 2010
  • 5603 Answers
SOURCE: Peavey PR15D amplifier board. What
You can contact Peavey and they will send you the schematics. If you can tell me a few characters of what is on the chip I might be able to give you a clue. For power amps they often use the LM3886, an eleven lead power amp clamps to a heat sink. For typical small 8 lead op amps the often use 4560's.
Posted on Mar 23, 2011
  • 5603 Answers
SOURCE: My Peavey PV-118 18" subwoofer
Peavey uses a protection network and sometimes it gets blown when too much power is sent to the speaker. The speaker may be blown however. Peak power for this is 800 Watts and 400 Program... That is NOT RMS power. Make sure your amp is no bigger than 300 Watts RMS driving this. If you are REAL lucky, maybe a lead has fallen off the speaker... Open the unit inspect and test the components.
Posted on May 16, 2011
My peavey amp pv 2600 only plays on channel A. No output on the B side
Check the "BRIDGE" switch position, "IN" for "BRIDGE", "OUT" for "STEREO", and clean ALL back switches with a cleaning spray and then run the amp again, also check the two green lights activation at front, if they activate, then amp is certainly working, let me know further.
Jan 28, 2013 | Peavey Pv 2600 Power Amplifier
Power problems with my Peavey PV-1500
Suspect that the pot is broken, or start cleaning all the back switches, this pv amps suffer from a terrible switch quality.
Mar 15, 2012 | Peavey Electronics Peavey Pv 1500 Power...
May 15, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
Peavey PR15D amplifier board. What is the part number of U5. The IC is damaged and can only read the beginning of the part #. Starts with HC.....
Mar 22, 2011 | Peavey Electronics Peavey PR15D 15" 200...
How to disassemble Peavey Amp model PV-900 i just need to clean it cause one of the plug (1/4 or xlr) won't works correctly, i need to make a presseure on it to listen sound from one of our...
You will need to remove either the top or bottom panel to get at the jacks. There is probably a bad solder joint that needs to be repaired. You might try tightening the screws on the XLR jacks that fasten them to the back panel first and the nuts that fasten the 1/4"jacks also. I really do not recommend you do this yourself ( accessing the interior) unless you have electronic servicing experience as the filter capacitors in the power supply store a dangerous charge and are soldered to the circuit board in fairly close vicinity to the output stage.
Oct 09, 2010 | Peavey PV® 900 360W Power Amplifier
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
I need a solution to repair peavey pv 2000 power amplifier.
Dan
Jul 11, 2010 | Peavey Pv 2600 Power Amplifier
Power supply problem
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Jul 02, 2009 | Peavey Pv 2600 Power Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Peavey PV6 Mixer Logo
64 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
