Question about Danby DTT420W Portable Washer
MY DANBY DDT420W WILL NOT FILL WITH WATER IT WILL START THEN ABOUT A GALLON IN IT STOPS ANY SUGGESTIONS ON WHAT IT COULD BE
Wont fill to proper water level
  • 1462 Answers
SOURCE: I recently purchased a danby
if in a soft water area, no need to do anything
Posted on Aug 05, 2008
  • 340 Answers
SOURCE: connecting a hose to take out condensation Danby dpac7008
you'll have to take it apart their is a switch which will have to be by passed .hook up your hose to a drain good luck . Tom
Posted on Jun 18, 2009
Maytag317
  • 1136 Answers
SOURCE: my danby fills and immediately drains.
Hi, It sounds like the drain hose has dropped lower then the water level in the washer. Check and see if the hose end is as high as the top of the washer.
I hope this helps you.
Vic
Posted on Jul 10, 2009
tebot
  • 15 Answers
SOURCE: Danby dpac120068 Air Condtioner, where does the
The hose goes into the empty tank or tray inside (if it's the drain hose like a garden hose). When the hot side of the system goes past there it evaporates the condensation dripping into it. If your talking about the big 4 inch hose, that goes out a window to get rid of the heat from the room.
Posted on Jul 28, 2009
  • 327 Answers
SOURCE: water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Posted on Jun 04, 2010
How can I adjust the waterflow to a lower setting to make it 1.2 gallon flush from a 1989 3.5 gallon flush??
Keep in mind that if you limit the amount of water too much, the 3.5 gallon toilet will not flush properly.
This looks like an old Kohler Rialto toilet. The proper way to adjust the water level is to tighten down on the adjustment screw located on the very top of the fill valve. The fill valve is the the piece that the float ball screws into on the left side of the tank.
Tighten the screw down and flush the toilet. Wait for it to refill, and check the level. If you need less water, tighten again, let fill and check level.
There are also two old school methods to save water in your toilet. One is to put one or two bricks into your toilet tank. This reduces the amount of water that fills the tank. The second method is if the fill valve has a float ball on a metal rod, you can bend this rod down into the water. This makes the fill valve shut sooner. Don't bend too far or too fast because the chlorine in the water weakens the brass rod that the float ball attaches to.
Nov 29, 2016 | Home
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
Press the start button,you hear a click,water runs for a second or so, water stops,that's it. Nothing else happens. Any suggestions. Thank you,S.Nielson
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 19, 2011 | Frigidaire Washing Machines
If you have a five gallon bucket and a three gallon bucket and there are no measurement marks how do you calculate a perfect four gallons
Hello! Fill the five gallon bucket...Dump its contents into the three gallon bucket until it is full...leaving two gallons in the five gallon bucket...fill the five gallon bucket...Pour the five gallon bucket into the three, filling it...Tthis leaves exactly four gallons in the five gallon bucket...
Guru.......saailer
Mar 22, 2010 | Garden
When the water has reached it's proper level, the hot water turns off, but the cold water keeps filling until the water overflows the basket
Try this. With the wash tub empty, start to fill with water. Without turning washer off, unplug the washer from wall.
If water filling stops (hot and cold), then you are looking at a bad timer assembly. Replacement isn't that hard, parts can be difficult to find though.
If water continues to fill, your valve body / solenoid assembly is likely full of lime-scale. Easily replaced.
Jan 04, 2010 | GE WVSR1060A Top Load Washer
Danby DTT420W Portable Washer Logo
23 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
