Question about Kitchen Ranges
Frigidaire electrolux professional series oven
So the saga started last night when we tried to put our oven (Frigidaire professional series cplgf390dcb) into self clean mode for the first time. Got a F9 error, so tried resetting the breakers. After this, the display flashes "Door locked" and oven is completely inoperable. The locking latch is MOVING back and forth from the lock to unlock position (display still says "door locked"). I have tried to push all combinations of buttons, and have called the company but nothing has helped. The locking latch is still moving from lock to unlock back to lock, etc. I've scoured the internet but no one seems to be having this problem. I tried resetting the breakers again, but nada. Suggestions?
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 322 Answers
Regardless of the course of action you are taking to fix your problem, especially if it involves opening the oven, start off by thoroughly examining the user manual first:
Frigidaire professional series oven manual
Posted on Jan 09, 2015
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Check the wiring to the lock.
Posted on May 01, 2014
josh1856
  • 105 Answers
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
SOURCE: Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Posted on Sep 14, 2008
  • 38 Answers
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
heatman101
  • 43501 Answers
SOURCE: Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 21, 2010
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Dec 03, 2014 | Electrolux Frigidaire Professional Series...
The door on my frigidaire professional series will not lock on cleaning cycle. oven stops the self clean cycle because the door is not locked???
Hi Glenn, thank you for allowing me to assist you!
Based on the symptoms you are describing, you may either have a communication error from the EOC (electronic oven control) or faulty door lock assembly. Let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your range on. If resetting the power does not correct the issue, at this point I would highly recommend reaching out to a service technician who would be better able to assist you in the diagnosis and repair of your range. You can often locate an experienced technician in your area by going to the manufacturer website.
Dec 03, 2013 | Electrolux Frigidaire Professional Series...
40 duel fuel frigidaire/electrolux convection oven doesnot work self cleaner doesnot work .
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
Apr 14, 2013 | Electrolux Frigidaire Professional Series...
Frigidaire electrolux double oven pro series upper oven not heating properly wont keep temperture
Hello theeggleton6 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately for proper diagnosing.
Nov 14, 2012 | Electrolux Frigidaire Professional Series...
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
Oven door locked and fan going frigidaire professional range
Did you solve your problem? I just got stuck in the same situation! How did you stop it?
Jul 09, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Jan 22, 2009 | Electrolux Frigidaire Professional Series...
Kitchen Ranges Logo
130 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
