Question about Cyber Acoustics Audio Players & Recorders
Cyber Acoustics CA-3618 subwoofer cuts in and out.
The subwoofer cuts in and out with crackly static. It is not on more than it is on. Before this started happening it used to take a few minutes to warm up before the subwoofer would come on and stay on. Now it barely works. There is pretty much no way to work inside the box unless i cut a hole in the back.
  • Cyber Acoustics Master
  • 3,320 Answers
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
Posted on Mar 26, 2014
  • 2 more comments
  •  Mike M
    Mike M Mar 26, 2014
  • Erich Friebel
    Erich Friebel Mar 27, 2014
    That's what I figured. I saw some similar products at Staples for $30-50. Any suggestions for something decent that will last and have good sound quality without breaking the bank?
  •  Mike M
    Mike M Mar 27, 2014
    Any 2.1 system in the $40-$60 dollar range should be more than adequate. If you can, stay away from "Feature rich" systems as what you want is sound not gimmicks. Also, think about where the speakers are being used. 40-50 watts is good. If you can go to a store and try some out.
  • Robert Furuglyas Apr 07, 2014
    I had the crackling on my A-3640 set. I was able to clean the dial (poteniometer) with rubbing alcohol. I bet you can peel the bottom off that speaker to expose the guts of the controls. If you are attempting any repairs then make sure to unplug everything so you don't injure yourself or cause damage to other components. After I got mind taken apart, I dripped the alcohol into the dial housing then moved the dial back and forth a bunch of times. I then blew into the housing to evacuate the alcohol and dirt. Once it dried, I reassembled it and now the crackling is gone. If it still crackles, the poteniometer (dial) is bad either by defect or use. As for the sub not turning on, it sounds like bad capacitors. If you want to check the caps on the amp, once again make sure to unplug everything to avoid injury or damage. You should be able to get the face of the sub box off with some coaxing. Once removed you can then remove the speaker to have access from the front of the box. This will help while guiding the amp out the other side. To remove the amp you will need to peel off the shiny sticker with the port labels on the back. You can then remove the four screws on the corners. It should then be able to be carefully manuvered out the back of the sub enclosure. I suggest searching the internet for how to identify bad capacitors. Swollen tops, leaking fluid, split, etc. Age can also cause them to fail. I betting you have some bad power supply capacitors. If you are going to attempt replacing bad caps make sure to pay attention to thier ratings. You'll want to make sure to get the same uF rated capacitors. You can get same or slightly higher voltage but never lower. I know this because my 2.1 set isn't as easy to replace so I've been repairing it. I've replace the subwoofer itself with an 8" Audiobahn 250 watts. Also have plans to replace all the capacitors on the amp. Been 8 years of constant use and about time for some to fail. I opted to fix mine because an equivilant system would run me closer to $100 and why do that when I can fix it with upgrade parts for a lot less.
4 Suggested Answers
CLUEPATEL
  • 138 Answers
SOURCE: subwoofer cuts out
Its due to the damaged pin in which you r inserting the subwoofer pin!
Posted on Dec 08, 2007
SOURCE: Subwoofer works - sound goes away after some time
POSSIBLY A BREAK IN THE SPEAKER SUPPLY LEADS TO THE ACTUAL BASE UNIT
WE HAD THIS AND IT WAS NOT THE SPEAKER BUT THE BOLT ON CONNECTION UNDER THE SPADE TERMINAL ON THE BACK OF THE BASS UNIT
Posted on Dec 31, 2008
  • 42 Answers
SOURCE: Unit was working for a
sorry, but from your description i dont think there is much help for your sub. unless its new and under warranty. that sounds very typical of a dead sub. i have had a bad run in with sony products just quiting only after a few years. i try to stay away from anything with the word sony on it. a short list of the sony products that i can rememdying only after a year or so cd boom box (3 of the same one) sony 19" tv, sony handi cam (video camera two weeks after warranty peroid), component cd player, alarm clock radio.... the list is longer but i will stop. sorry for your trouble.
Posted on Dec 24, 2010
While listening to my sony xplod 52wx4 , the radio signal is fine for several minutes and starts breaking in and out with static. I have reset the stereo and the same thing happens. I have checked the
I'd hate to say, but sounds like part of your tuner is going out/bad solder join/heat sensitive. Hope it isnt to old. Might call the manufacturer and see what they have to say.
Jan 22, 2014 | Car Audio & Video
LEFT SPEAKER HAVE STATIC SOUND AND NOT CLEAR
Hi what are you listening to like cds or tape or radio also are you using copy cds
Apr 02, 2008 | Kenwood KR-X1000
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
When driving suddenly the engine cuts out.
I heave the same problem on my Corsa B 1.0 2000, engine cuts out, and whe it happens, I hear one of the relay under the right side of the dash buzzing. After a couple of minutes, starts like nothing happend.
So far I manage to find that the speed sensor is faulty, when I tap him the car stops. I order a brand new one, but I'm not sure that was the issue.
I order also a Opel Tech2 tester from ebay and it has to arrive next week, then I can see the error code.
Jul 13, 2012 | Opel Cars & Trucks
I'm having a problem where the subwoofer of my Home Theater system cuts out on me. Indicator light constantly changes to red for no apparent reason. I find that unplugging/replugging the RCA cable from...
If this is happening only with subwoofer section and all other channells are fine. Then this could be because of the electronics inside the amp box. or sometimes may be bad contact at subwoofer cone also. But as you said by volume up and on/off makes it alright, then the probability is more with electronics inside.(draining signals)
Dec 14, 2010 | Audio Players & Recorders
Subwoofer does not play at full power
Sounds like you have an amp problem.
The only place to get this fixed is Velodyne.
Apr 09, 2009 | Velodyne SPL1000R Subwoofer Speaker
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Older TV keeps going to static
Without seeing it I would suspect a bad connection on the main board. As the board heats up the board expands and as it cools in contracts opening and closing a crack in the board. Sometimes a crack or bad solder joint both are sometimes hard to find and it is a lot of solder and wait and see.I have had some luck by tapping on the board with an insulated handel of a nut driver,.. the tv on and watching for any change. If i tapped around the board some areas were more sensitive than others. I then soldered that area. I would tap around again if the set did not react I assume the problem fixed
Jul 19, 2008 | Philips Magnavox 27MS343S 27" TV
No subwoofer signal
your out put signal circut bord is shorted out. It happens when there is static feed back from output continuity to an electric overload inside the unit. Then when you have a shorted board then it will eventually go into a protect mode and nothing will work ...just the power light will turn red and blink.
Just a suggestion.....Get rid of it while it has a bad sub output signal. you can get some money out of it.
I can always use extra parts for the other denons I work on....call me if you want...630-742-6587
Rick
Jul 07, 2008 | Denon AVR-1705 Receiver
Subwoofer cuts out
Dec 08, 2007 | Audio Players & Recorders
126 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
