Question about iLO 3200 32 in. LCD Television
Water damage on left corner black orbs on right corner that continue to grow bigger each day. lines (very thin on screen).
My daugther sprayed cleaner on our vizio tv screen, and now there streaks and a ***** of black pixels at the bottom. Is the tv junk now? Can it be fixed? Will it get worst? Thanks!
Posted on Aug 24, 2009
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Very thin black vertical line moving across tv screen left to right on tv
The screen voltage to the picture tube is more than normal. Adjust it by the help of screen pot-meter integrated with Line Output Transformer. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 05, 2012 | Panasonic CT-20SL14 20" TV
Display has black circles lower left corner and upper right corner. were smaller but have grown. Maybe 2 in. each now. Also lines in pink and black across bottom. Everything else works OK. Bought past...
Well your on the right track I would say it's your LCD because your video chip wouldn't make black circles I don't think. The pink and black lines are a symptom of a LCD that has been broken and the circles sound like someone squeezed it to pick it up by the screen maybe. That would be for your venders warranty department to figure out though. If you really want to know you could buy a cable to hoot it up to an external video source if the display is fine, it's defiantly your LCD.
Jul 29, 2011 | Dell Computers & Internet
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Sony 40 inch lcd television
Call Sony!! It Will get worse!!! The panel has ribbons that have fine wires that are used to show each line of information on the screen. Either the panel is going or the wires are loose. Either way, the panel needs replacing. Just hope to God it's under warranty or if not, sony will help you out with a buy-out.
Aug 07, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Maxent 27" LCD Flat Screen TV
This is a fault i have seen with phillips lcd tv's and i suspect it could be the lcd screen itself,the ribbon cables from the screen are heat contacted on to a circuit board and there could be anything from 10 to 15 of these ribon cables and over a period of time the heat generated from the internal panels will deteriorate the plastic ribbon cables.
Try twisting the screen gently by placing your left hand on the top left hand corner and your right hand on the top right hand corner and gently twisting,if the lines go and then come back after you let go then a new screen will be required but it may be cheaper to buy a new one,could be worth buying the extended warrenty.
Feb 02, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
iLO 3200 32 in. LCD Television Logo
262 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
