Guys Im using Sony walkman nwze463 The device is not getting charged as I used original charger as well as used a newly purchased one It is not turning up when I plugged directly to switchboard or to computer Initially I thought the problem was with the data cable but later I found that charger seems to have no trouble I also used the reset option provided at the back of device Terribly annoyed Help me out
  • 10,263 Answers
Data cables are different from charger cables. Charge only cables will never pass data and vice versa. Check the style of cable you are using to charge your device. The connector on the device may have lost a good connection inside the device or the connector solder joints internally may need to be re flowed.
Posted on Jul 28, 2017
SOURCE: Sony NWZ-A816 won't charge
I had the same problem my mp3 would not charge.To fix connect the mp3 to your computer with the usb cable, go to Device manger open up portable devices you should see a small yellow triangle (this is telling you some thing is wrong) right click over walkman and choose up date driver .windows will use hardware wizard on the net to fix the driver.This worked for me i hope it fixes your problem
Posted on Oct 30, 2008
SOURCE: MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Posted on Dec 28, 2008
SOURCE: I have a Sony NW-E005F
yaah i had solution for this
u shouldnt format as regular pendrive
u should format throu mp3 play er only
u r having an option home button,press dat button
go to menu option
in dat goto advanced menu
in dat go to initialize
u will have an option format use dat option n format ur player
then u will apper a message COMPLETE
THEN LOAD UR SONGS THROU SONY STAGE
Posted on May 25, 2009
donchimei
  • 33 Answers
SOURCE: Sony Walkman NWD-B105F, Creating Database
try using sonic on your computer.
Posted on Feb 18, 2010
  • 608 Answers
SOURCE: MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Mar 28, 2010
Power bank issues and charging
This not an uncommon problem. Many people don't seem to realize that it is best to use the original OEM cord and charger for charging a device. Using a nonbrand name can cause a lengthy list of problems, including sub-par quality cables, which could actually damage your device.
Visit your service provider, one of its stores or mall kiosks and purchase the proper USB power cable.
Jan 01, 2016 | Cell Phones
I lost my charger , where can I find another charger in Phoenix Arizona?
It is not required to use a charger for charging the NWZ-E438F Walkman Player. You can connect the Player to the Computer using the USB cable for charging the Walkman Player. The charger is not supplied with the Player, however you can purchase the portable charger for the Player.
Recharging Time : USB-based charging Approx. 4 Hrs (full charge), Approx. 2 Hrs (approx. 80%)
The model # of the compatible charger is AC-U501AD and AC-NWUM50. Click here for the link to purchase AC-U501AD and AC-NWUM50
Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Jul 17, 2011 | Sony NWZ-E438F Digital Media Player
I CAN`T FIND THE CHARGER OF SONY DIGITAL MEDIA PLAYER
I'm glad to provide the instructions to charge the player. It is not required to use a separate charger to charge the player. You can connect the walkman player to a Computer using the supplied cable to charge the battery of the player. Alternately, you can use an USB charger available from Sony to charge the battery.
I have provided a link where you can order for the replacement cable if you lost the supplied cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665234500
I have provided a link where you can purchase the USB charger for the player.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665234497
Thanks for understanding. Please let me know if you require any clarifications.
Jun 26, 2011 | Sony NWZ-E438F Digital Media Player
I have 2 sony mp3 players and they both won't charge. charger is working
hello there !
Check your charger pins First are they OK.
then go for the Sony player charging point . is it clean enough that pins can make charging , if they aren't then clean with a needle.
thirdly do try to use a original Sony charger as i had some players back and it wont work cause i didn't use a branded charger .cause the out put sometimes get different and they are not of slandered quality.
Do comment if it helps you in any manner
ill give you a feedback
Apr 23, 2011 | Sony Walkman Video NWZA818 MP3 Player
My sony ericsson w705 no signal and not charging problem
use only sony w705 original charger....dont use duplicate
Mar 05, 2011 | Sony Ericsson Walkman W705 Cell Phone
Where can i get a charger for my player (NWZ-E435F Digital media Player Sony corp. S/N: 5083578
The NWZ-E435F Walkman Player can be recharged by connecting it to the running Computer USB port using the supplied USB Cable.The Battery icon will get displayed and indicates the icon during charging.
However, you can try using the AC-U501AD USB charging adapter for charging the Walkman player.
Thanks for using FixYa.
Mar 02, 2011 | Sony Walkman NWZ-E435F Digital Media...
My sony ericsson w810i phone is not charging through charger but is charging with data cable. The charging jack has been recently replaced. What is the solution for this?
sony ericsson phones have their own two-prong charger/data plug. You will need to purchase another AC charger, or you can purchase a plug that has a female USB and use that. Good luck!
Nov 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
Not able to charge the battery
As per Sony, if you are getting this message, it's a concern.
This message usually appears, if you are using a Battery other than Sony's.Make sure you are using Original Sony's charger. Try to use some other Charger and Battery.
If problem persists, you need to send the unit for repair. More likely, it's a firmware issue. I have hardly seen any Charge / Battery issue.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 13, 2009 | Sony Ericsson Walkman W705 Cell Phone
My Walkman won't charge
What I did when I got this error was to push the reset button on the bottom of the player itself... Mine rebooted and took a charge from the computer. Hope this all works for you.
Aug 10, 2008 | Sony Walkman NWZ-S616F MP3 Player
 Grubhead
Grubhead
