Question about Honeywell ER150B Air Conditioner
Replace battery The "replace battery" sign is on and the air conditioner has nothing on the display screen. Regular air is coming out of the vents, but not really cold. How do I change the battery? Is that even the problem? This is a Honeywell product.
    Scholar:
  • 104 Answers
Yes, the battery must be replaced. Gently lift or pull of cover, the battery compartment is there. Best of wishes.
Posted on Jun 15, 2009
Is the vent hose on this unit supposed to get really hot?
yes it is normal . most of these have a flexable metal tube that vents them , you can use a dryer vent tube but it will get hot and even melt a little
these units do not have a long service life so don't waste your money on factory replacement parts , just use the way you are till it's used up.
Feb 01, 2016 | Everstar Portable Air Conditioner MPK-10CR
Replaced battery on 2006 murano and now display for radio, air, etc does not come on
According to the owners manual - -
To turn on the screen, push the "SETTING", trip
control, air conditioner (except rear window defroster
button) or audio button.
There's nothing in the book about special instructions should the battery be disconnected, so if the screen will not come on I would guess a fuse or something happened to the power source.
Jun 27, 2012 | 2006 Nissan Murano
When the central air turns on it is very loud. I assume its the fan or whatever is in the attic. it sounds like a really loud regular window air conditioner on high coming through all of the vents. Is this...
No. This can be caused my a dirty squirrel cage on the blower motor which is found in your air handler in the attic. Probably needs to be pulled out and cleaned. This noise is caused by the blower wheel out of blanace.
Jun 25, 2010 | Heating & Cooling
I changed the batteries and now the house will not cool down. The lowest i can get the house cooled to is 76 degrees, and that is if i turn the thermostat down as low as it will go. The air coming out of...
Check the filters. Clean or replace them. If you are refering to the batteries in the remote, look for a reset button or hole and stick a paper clip in it. You will have to reset your clock.
Jul 16, 2008 | Honeywell Heating & Cooling
Buttons
F1, F2, and F3 are the strength of the fan blowing the air conditioner. F1 circulates the least amount of air, F3 the most. I generally find that if the air conditioner isn't getting the job done on F1, F2 will do it. I typically only use F3 if I just want to circulate air fast in my place for awhile. As far as what is "better" with closed vent or open, that depends on what you want to do. If you are using air conditioning on a hot day, then vent closed is better because it will cool only air circulating in your place. Vent open will allow fresh air in from outside, and if it's a really hot day, the air conditioner might have a harder time cooling off the fresh air than the circulating air inside your place (as it's continually being cooled repeatedly by your air conditioner).
Jun 10, 2008 | Goldstar M1003R Air Conditioner
Fujitsu remote control unit /MODEL AR-RY16
my remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Jun 07, 2008 | Fujitsu 24C1 Air Conditioner
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
Honeywell ER150B Air Conditioner Logo
218 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
