Question about Casio 10 Gzone C751 Btr751 Ravine Battery Btr751b For Verizon Cell Phone
Casio c751 motherboard replacement
Replacing motherboard
Where can I find casio c751 drivers?
Type "casio c751 drivers" into a well-known search engine.
Jul 03, 2014 | Computers & Internet
Won't receive calls
turn the ophone off and then back on
Feb 25, 2014 | Casio Ravine GzOne Ravine C751
Casio g'zone phone with broken screen main screen.
This is most likely a broken data ribbon. It is a few very thin wires that connects the mother board of the phone to the screen and can easily break with flip phones. It can be replaced and new data ribbon is cheap.
Oct 05, 2013 | Casio G Zone C751 Ravine Verizon Cell...
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
I have a casio G'Z ONE C751 and were the charger plugs in and lose need some help to fix
I dont think you will have success repacing the plug in the phone. You might have some luck tigntening the fit if, with a LOT of care, you change the male part (on the carger) by bending ever so slightly with an awl or pliers. I have the same phone and I live with the fit.
Dec 07, 2012 | Cell Phones
Busted motherboard
The board is cracked? "busted"... replacement only solution. If non-operational repair the unit. Failure to connect via USB is COMMON and is not indicative of "busted" motherboard.
Jul 11, 2011 | Casio Ctk-5000 Electronic Keyboard Piano...
Droop camera
Hi!
If it's a Casio S500, it could be damaged CCD or just loose connection between the CCD and motherboard. You should take off the front cover and see the two cables on the left of the lens - I would recommend you using tweezers to reconnect the cables. If this doesn't help, you should get a replacement CCD. You can contact your local Casio service center, look for CCD (could come with lens) on eBay or contact me at toms.safranovs@gmail.com.
Hope this helps!
Tom
Jul 29, 2009 | Casio Exilim EX-S500 Digital Camera
Casio 10 Gzone C751 Btr751 Ravine Battery Btr751b For Verizon Cell Phone Logo
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
