I can not find the filter in my goodman a36 15
I can not find the filter in my goodman a36 15 furnace
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: Where is the furnace filter located on the furnace
Hi, this is a pretty generic answer, so it's really more of a guideline.
Some come attached at the bottom of the furnace, and are generally removed when the unit is installed. If it's there, it pulls out like a drawer.
Most furnaces are installed on a platform, which is really a box (plenum). Below the platform, and opening to the room, is a louvered grate. Air is drawn in through the grate and into the furnace. The grate has clips on it to keep it closed. Loosening the clip(s) allows the grate to be opened. The filter is usually behind there.
Best regards, and hope that this helps,
--W/D--
Posted on Jan 21, 2011
What is the best replacement filter for a goodman AWB24-05D?
Measure your old filter and search the site airfilters.com - they have 7 different air filters for Goodman furnaces.
Apr 06, 2017 | Goodman Heating & Cooling
Where is the air filter for a Goodman # CAPF036A2A
If this is a case coil, they do not have a filter area, the filter is normally either installed in the return air grill or needs some type of filter installed just upstream if in a down air installation in a closet. If it attached to a furnace, there is a space provided by most manufactures for a filter installed just before the air return. If the furnace is in the attic or in a crawlspace, I never install a filter in these areas, but put a return filter grill in the return path.
Hope this helps
Feb 10, 2015 | Goodman Heating & Cooling
Goodman furnace
Sounds like the furnace is tripping off on a limit safety, either temperature or air switch. Check filters and restrictions to air flow (furniture over return air grills, blocked filters) also, check the drainage line of the system. If the furnace can't drain water fast enough it will back up internally, and trip the system off on a pressure switch safety.
hope this helps.
Mar 18, 2014 | Heating & Cooling
Furnace won't start after replacing filter
check for disconnected wires . There may be a sensor in or near the unit you touched that is causing the problem
Feb 18, 2013 | Goodman Furnace Draft Inducer Blower ...
Goodman ARUF364216AB will not turn on I replaced the air filter and turned the main breaker off and on twice which did not help.
There is a kill switch behind the cover that you removed to change the filter...make sure the cover is on correctly or maybe the switch went bad...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 05, 2011 | Goodman Heating & Cooling
How do I locate and change the furnace filter?
Your filter will commonly be on the side of your furnace where the return air comes in, usually it will slide into a filter rack or you might have a small cover on it. When replacing a filter make sure the arrow on the filter is pointing in the direction of airflow, so the arrow should be pointing toward the furnace.
Jan 21, 2011 | Goodman Heating & Cooling
How do you change the filter on model# GMP075-3?
When looking at the front of the furnace, toward the top, turn the two black tabs so they are vertical, then pull it forward. This will take off the top panel. Now pull the bottom panel up, then toward you. You can now see and change the filter.
Dec 02, 2010 | Goodman GMS90703BXA Heater
I have a goodman furnace (GME-8) and i cannot locate the air filter?? any idea where i should look?
It should be in the return air duct. The place the air is removed from the building on its way to the furnace.
Oct 27, 2009 | Goodman Heating & Cooling
Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Apr 23, 2009 | Goodman Heating & Cooling
Furnace filter on model gmt070-3a...
look in and around where the blower motor is located. there has to be a filter compartment there. probably near the bottom as it looks like an upflow heater. make sure the filter door is closed. it may have a door interlock switch that cuts the burner out if it is not fully closed.
Feb 01, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
