Question about Dacor Preference RV36 Kitchen Hood
Dacor Pinnacle Raised Vent
I washed and replaced the front grill. I thought I had replaced it correctly but, on the next use the grill slipped down into the unit. I can not reach it, how do I remove it?
  • 3 Answers
Unfortunately i had found myself in this same situation. i have no idea how the grill came out when it was closed, but it was stuck in the fan enclosure underneath the counter. Unlike the poster above i did not have access to the side screws to take the unit apart. instead i was able to remove the front panel, and then unscrew the motor arm from the protective case, and unscrew the case from the unit. This created enough wiggle room that i could raise the right side of the vent cover up and extract the left side out the bottom opening. then it was just a matter of reconnecting the arm to the cover and the cover to the unit.
Good Luck,
-Mark
Posted on May 25, 2010
Pinnacle raised vent RV36 or RV46.
Disassembly will be necessary.
Jul 02, 2016 | Dryers
My Maytag Performa electric dryer heats and tumbles, but the clothes take multiple cycles to dry, and water is pooling next to the left front foot. We cleaned the vent, replaced the vent hose, and opened...
two things come to mind; 1. although drum is rotating perhaps it is slipping under load. Change drum belt, and, 2. perhaps the problem isn't in the dryer, it could be that your washer is not spinning out properly leaving an inordinate amount of water in your clothes which would tax the performance of the dryer. Just a thought. good luck!
Aug 19, 2013 | Dryers
I need to know how to clean a dacor raised vent
two Phillips screws under side of raised vent removes top complete then switch has plastic piece that slides out with control be careful wires are short and very small easy to break
you will most likely have to change keyboard and buttons
Oct 01, 2017 | Dacor 30" Slim Raised Vent, in Stainless...
Light goes off and on by itself
I have the same problem with a DACOR ECS 130 and also set the breaker panel switch to OFF to prevent the light from turning on-off or staying on. It might help to unplug the touchpad connector behind the control panel or it may be a problem relay on a circuit board. I've had the problem for several years but will start work on it tomorrow because we do not bake often at my house.
Bill (bsquared37@yahoo.com)
P.S. I'm not an appliance tech but have had problems with the DACOR DM024 microwave( made by SHARP) and the DACOR raised vent. I think DACOR products are junk. The raised vent problem required replacing the entire circuit board!
Aug 30, 2009 | Dacor ECS130 Epicure Electric Single Oven
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
New Dacor Vent does not work
Hi, we have a Dacor RV 30 (I think) and twice I have had the unit go up and down endlessly until I turn the breaker off. The problem was water getting inside the switch. The first time, I got a real Dacor replacement ($80?) the next time, I got the part number off the switch, googled it and got two of them for about $4 each plus shipping.
Mar 22, 2009 | Dacor : 36" Pop-up Intake System RV36S...
Raised vent is Rising after being lowered
My RV30S was installed by a qualified service technician in approximately the year 2000. It finally developed a mind of its own. It would raise up and run for a bit and then stop....sometimes it wouldn't raise up or go down....it would switch from fast to slow to stop.....it became frustratingly unusable....
...today i finally took it upon myself to take it apart and I determined that the controller board had fried.
Before I go on -> Disclaimer: These units are hard-wired to live A.C. power. These units must be serviced by technically qualified service personnel. I do NOT recommend anyone to attempt this service. I've worked in the past as an electrical engineer by trade. But to save you time and money you can shop and buy the parts you need yourself and then hire an appliance service technician to safely install them for you. This way they can't rip you off by over charging for the parts and you can certainly count the hours for the install.
The controller board is shown here. In my case, this diode fried.
I found a replacement controller on E-Bay for only $82 bucks and change. At the time of this writing they had 14 in stock.
http://cgi.ebay.com/NEW-Dacor-Vent-Hood-Control-Board-DA-72881_W0QQitemZ120363680495QQcmdZViewItemQQptZRanges_Cooking_Appliances?hash=item120363680495&_trksid=p3286.m20.l1116
It sounds like you may be having the same problem. But please be sure to hire a qualified appliance service technician to do the work. If he quotes a price for the controller board anything over 82 bucks, you will indeed will be in a better position to negotiate a better deal.
Hope this helps anyone that is having or will have the same problem with an older RV30....
Dec 08, 2008 | Dacor Preference RV36 Kitchen Hood
Pinnacle Raised Vent System #RV36 or RV 46
Ours started doing the same thing. I got it to start working again by gently holding down the up/down button until it started to move. After doing this a few times it started working normally again. Also the keypad can be locked and unlocked by pressing the low and high buttons together for 1 second.
Dec 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Jun 08, 2008 | Dacor Preference SGM466 Gas Cooktop
Dacor Raised Vent Buttons reply, sc58@aol.com
There are two small screws on the bottom of the top lip. Remove them and pull out the endcap inserts. The top shoudl then pull up with maybe some light force. Then you can get to all the bottons.
Apr 20, 2008 | Dacor Preference RV36 Kitchen Hood
Dacor Preference RV36 Kitchen Hood Logo
1,052 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
