Question about Kenmore 24 in. 16492 / 16494 / 16499 Built-in Dishwasher
My kenmore door facing is starting to rust
66513272K110
  • 957 Answers
You can go to applianceparts.com and order a new panel.
Posted on May 22, 2014
Kenmore 110.62622101 dryer door hinge is broke
It will be as you are facing the unit.
Sep 08, 2014 | Kenmore Dryers
The top door is rusted out where the hinge fits. I want to patch it up to use in my shop. I tryed mounting some flat type door hinges but it don't work well
without knowing the refrigerator its a tough one, but refrigerator hinges are designed to allow the magnetic door seal to seal properly, flat door hinges typically not a good choice for this application
  • Either pop rivet some new metal plate to replace the rusted area and use existing hinge
  • try get replacement door from used refrigerator or refrigerator recycle place.
  • buy new/used fridge from kijiji :)
Aug 24, 2011 | Kenmore Top Freezer Refrigerator
My Kenmore washer Model 44152 leaks from under the front door. It appears to be due to the clothes pushing against the plastic door (front loader). The extremely flimsy door bends very easily. The area...
hello, 99 percent of the time replacing the bellow which is the rubber part the door closes against will fix this problem! Not the door.. hope this helps.. dont forget to rate me. Thank You
Jun 07, 2011 | Kenmore Front Load Washer
I have replaced the rotors and pads. Really didn't start to pulste until I did the brakes.
Take it all apart and start over. You obviously didn't do what was required.
Did you remove all rust from rotor mounting hub face?
Install new rotor or remove all rust from both hub and wheel faces and machine rotor.?
Remove all rust from caliper slides and pad sliding abutments and use correct lubricant, in proper spots.
Install the very best quality, vehicle specific pads (Rebestos,Wagner,etc)
Flush and bleed system coorectly.
Are the calipers old and rusted inside, and piston not retracting?
Sep 19, 2010 | Chevrolet Silverado 2500HD Cars & Trucks
I want to reverse the day on my dryer. How do I
If this is a Kenmore Elite dryer this is possible. Just follow these steps:
1. Remove the dryer door by supporting the door while removing the screws on the hinge.
2. Lay the door face down on a good working surface like a table. Place some towels under the door to protect the surface.
3. Remove the series of screws on the INSIDE of the door and it comes apart in two halves.
4. Remove the hinge from the door and remove the plastic blank from the opposite side of the door.
5. Remove the door front plexiglas and rotate and reinstall so the door handle is on the oposite side of the door.
6. Reinstall door hinge on the opposite side of the door and reinstall plastic blank to cover where the hinge used to be.
7. Reinstall the inner door facing and screw the two halves together.
8. Pop out the small plugs on the door facing, so you can reinstall the door to the dryer. Place the plugs into the orginal screw holes on the opposite side of the door facing.
9. Reinstall door. The door will now open in the opposite direction.
Since the door switch(es) and catch are located on the top and bottom of the door facing (depending on model number) you don't have to worry about removing any switches or door catches.
This is a fairly simple process that shouldn't take you more than 30 minutes to accomplish. If you have any questions along the way, please post back and let me know. I hope this helps.
Feb 11, 2010 | Kenmore Elite HE4 Electric Dryer
Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
its what we in the business call "refrigerator cancer" they are rusting form the inside out. there is not repairing them and not worth the cost of replacing, you can take them off and spray them you might get a little time outta them. reason it happens is the insulation used years ago was fiberglass and would trap moisture between door and liner, eventually rusting through.. new refrigs are insulated with blown in poly-styrene. they don't hold moisture.
Mar 11, 2008 | Kenmore 94499 Refrigerator
Kenmore 24 in. 16492 / 16494 / 16499 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
