Question about Car Audio & Video
I have a Sharp compact disc stereo receiver model # SC-9000AV the compact disc player does not play. It will pick the discs up then put them down without playing.
The tape player & radio work but not the disc player
  • Judith Vaughn
    Judith Vaughn Mar 26, 2014
    it is a home unit not a car unit
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
tech48
  • 624 Answers
SOURCE: Alpine CDA 7878R - Hi Temp - won't play disc
Does it play the tuner but not the CD?
If it so, the problem is directly related to the CD deck. If not, the problem could be a sensor or any number of other components that may have overheated.
Try to reset the unit. Most of the time this error is an electrical problem not fixable by the end user. But it is worth trying to reset the microprocessor and see if that helps.
Here is a diagram of where the reset button is at. Press it in with the tip of an ink pen or paperclick, whatever you have that will fit into the little hole. Just hold it in a couple of seconds. Be advised that when yo reset the unit, you will loose all things in memory like the correct time, preset radio stations ect.
If this does not help you will need to have it checked out by a good repair center. These Alpine radios are very good radios and are worth getting fixed unless the estimate is close to what you paid for it.
good luck, I hope this helps. if so, a good rating would really be appreciated. You can always ask me for more help if you need it. I have been repairing car and home audio equipment for over 17 years.
Posted on Jun 21, 2008
SOURCE: DISCWON'T PLAY, RECEIVE MESSAGE "THIS DISC CANNOT BE PLAYED, PLAYBACK PROHIBIT BY AREA LIMITATIONS
i am ohamed scondo
i have pdf repair
Posted on Sep 16, 2008
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
Molson02536
  • 3854 Answers
SOURCE: my 2005 tahoe stereo radio still plays but the 6
Turn the radio off and disconnect the battery. This will reset the radio and cd player, NOTE:' MAKE SURE THE RADIO IS OFF OR YOUR GOING TO BE PROMPT TO ENTER A CODE TO REACTIVATE THE RADIO. Good luck and keep me posted.
Posted on Jul 03, 2009
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Why does radio keeps turning itself off after 15 min.?
Half a dozen reasons... If it's exactly 15 min maybe a timer is set? If it's only when it's played loudly or when a bass part is played it could be the wires touching each other.
Jun 07, 2014 | Sharp Cd-dh950 Cd-dh950p 5-disc Compact...
My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Apr 24, 2010 | Sharp AQUOS Blu-ray Disc Player
See add details
Since the receiver eventually works, the delay circuit is failing. This is a circuit that allows the power supply to settle down before kicking in the output relay. This prevents the "pop" that was sometimes heard on older units. This should be a simple and inexpensive repair probably requiring the replacement of a couple of small capacitors in that delay/protection circuit.
Dan
Mar 09, 2009 | Sony STR-DE935
Sharp MD MT-80H(S) not playing sony minidisc 80
I had a similar problem after not using player for several months - "Can't read" message displayed every time I put a recorded minidisc in the player. Seem to have solved it (maybe only temporarily) by opening the player, inserting little finger in at the righthand front and sliding movable mechanism from side to side. It looks to slide on a bar which had maybe picked up dirt or damp. Also tried blowing a warm hairdryer into the slot for a minute or two (take disc out first!) to remove any damp. Working OK at the moment.
Jan 19, 2009 | Sharp MD-MT80H Personal MiniDisc Player
CD's won't play on AIWA Compact Disc Stereo System
I have a Aiwa Compact 3 Disc Stereo Systen that will pick up the 1st CD, spin it for about 5 seconds, lower it and then go to 2, same thing, on to 3 and same thing. Please help.
Oct 30, 2008 | Audio Players & Recorders
My ancient Sharp CD - BA150 bookshelf stereo 3-disc CD player has suddenly stopped working. Even with 3 discs in tray, player won't recognize they're there and reads" NO DISCS" on LCD display....
I have repaired a lot of these exact Sharp stereo's and can say with certainty that you have a bad laser pick-up. The only cure for your problem is to have the pick-up replaced. It says no disc because that part is bad and can not read the disc, so it thinks there is no disc.
A repair for this would cost in the area of $125 to $150 depending on the rates of the service center you take it to.
This should give you the information you need to determain if it is worth fixing to you.
Sorry it is not something you could fix easy, but that is just the nature of these types of stereo's. That part, the laser pick-up, is a very expensive part. I have no idea why they charge so much for it, but it is killing the repair centers making so many of these too costly to fix.
I hope this helps, let me know if you require any further help.
Dave
Aug 27, 2008 | Sharp Audio Players & Recorders
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
