Question about Robertshaw 300-208 digital thermostat,2h,1c,nonprogrammable
The fault symbol is flashing and the red light is on, how do I determine the fault and how to reset after fault is found?
The system is working fine but fault light is on and fault symbol is flashing
  • Robertshaw Master
  • 10,045 Answers
You can get an operators manual on Robertshaw's web site. The fault could be that it's too co;d outside for the heat pump to be efficient. Once you get the manual you'll be able to find out exactly what's wrong.
Posted on Mar 29, 2014
Why won't security system let my car start
Because it's a security system, that's it's job. Check the security light, it should go out when disarmed and check the key symbol for red flashing indicating fault. Need to get a code to pin point, but you can also check to see if the steering wheel lock is working as this is a common problem for a no start.
Aug 23, 2014 | 2005 Nissan Maxima SE
Avocent kvm monitor flashing red light
So it's the monitor that flashes red? I would try the monitor on a PC to determine if the monitor is good. If not, replace monitor. If monitor works on a PC but not the KVM, power cycle the KVM. Depending on the model you may be able to do a hard reset. On other models you can access the KVM via IP to determine if there is an issue with the KVM.
Jul 29, 2014 | Avocent Computers & Internet
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
Hitachi L42VC04UI FLASHING RED LIGHT
Continuous flash of standby light indicates a fault in the serial data/clock bus line. Will be either a short circuit, or an open circuit. For both, this will be the symptom. If you are not sound in electronics, never attempt to do any thing with this set. Check this link for some details, and determine, whether you can do it by yourself or not. http://electronicshelponline.blogspot.com/ Pull up older posts there.
May 28, 2013 | Televison & Video
A key symbol on dashboard and lights are not working
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS, MIL, CEL and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System, MIL Malfunction Indicator Lamp, CEL Check Engine Light.
Nov 14, 2012 | 2008 Smart fortwo
Light is flashing on temperature control of heating pad
Trust me! This thing is a piece of ****! I bought one and loved the heat options that I bought three more for my wife and two daughters and their families. The next day mine went out. Took it to Walmart and traded it for another. Still pretty happy, figured I got a bad one. Three months later not a single one is working all have blinking green lights and won't allow you to do ANYTHING but unplug it! Five and all died the exact same death. Go to Walmart and each time they act surprised! NO WAY!!! This is a chronic problem with this product. I'm contacting the company tomorrow and am going to demand an ecplaination as to why they have not take this item off the market!
Jan 07, 2012 | Softheat Heating Pad HP218 12 3P
Hello My television does not switch on. Red light shows but blinks.
The light is flashing a fault code, it will be flashing in a pattern. Can you determine what it is? i may be able to help if you can determine the code.
Oct 25, 2010 | Panasonic Televison & Video
I have a NEC NDK 9000 PABX fault after relocating phone lines,1 extension is not working and the other 2 are, I have noticed there is a red light flashing on one of the cards and am assuming there is a...
Each PABX or telephone system needs its own driver as each system has its own output format for the SMDR port. Therefore the MonTel system must have a suitable driver (technically a receiver) for each type of PABX that it can support.
http://www.netwiz.com.au/appnotes/1872.htm
May 10, 2008 | Lands Phones
Robertshaw 300-208 digital thermostat,2h,1c,nonprogrammable Logo
453 people viewed this question
Top Robertshaw Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Robertshaw Heating and Cooling Expert? Answer questions, earn points and help others
