Operating repair manuals national rs 755s reel recorder
Finding Drive belt
  • Audio Player... Master
  • 1,258 Answers
Stereomanuals dot com
Posted on Jan 02, 2015
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
  • 231 Answers
SOURCE: where to buy replacement belts for a Akai model M3
Try this site:
http://www.turntableneedles.com/
Posted on Feb 28, 2010
Testimonial: "Thank you very much. Appreciate the good info."
Grubhead
  • 5056 Answers
SOURCE: I need a capstan drive
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Posted on Nov 06, 2010
supernova278
  • 1932 Answers
SOURCE: I need a repair Manual for a TEAC A-2300SD Reel to
You do not have free service manual for this product.
You can pay and download the service manual from below website
http://www.servicemanuals.net/ServiceManual/TEAC/A+2300SD+/pos1/results.aspx
Thank you
Posted on Dec 05, 2010
  • 115 Answers
SOURCE: I have a Teac A-1500 reel to reel tape recorder
I cant persobonally help you but you can try the manufacturers web site, and call for a replacement belt. Possibly try Radio shack and make a make shift belt.
Posted on Mar 31, 2011
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: pjheiland@hughes.net He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Audio Players & Recorders
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Oct 24, 2010 | Teac Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
The unit is eating up the tape!
Generally speaking, there are two reasons this happens.
[1] tape recorders have to move tape past the record/playback heads at a highly consistent and accurate rate of speed. What makes this possible is a rubber "pinch" or pressure roller and a spinning metal spindle. Tape is routed between the roller and the spindle, and when the recorder is in RECORD or PLAY mode, the roller presses the tape against the spinning spindle, causing the tape to move from the feed reel to the takeup reel. When the pinch roller and/or the spindle become coated with oxide particles shed from old tapes, they get sticky and the thin tape will begin wrapping around one or the other. THE SOLUTION is to get some cotton swabs and rubbing alcohol and clean the oxide (brown from cheap tapes and dark gray from better tapes) from both of these parts.
[2] many tape recorders use rubber belts and pulleys to turn the feed reel and the takeup reel. If the tiny rubber belt that makes the take-up reel turn is stretched, it will not wind moving tape fast enough, which causes tape to bunch up. If this is the problem (you will not be able to see the belts without removing the recorder's outer case), then you might as well junk the recorder.
If you see that the part of the rubber drive roller that contacts the moving tape has a ring of brown or gray coating on it, you
Feb 19, 2010 | Sony TCS-580V Handheld Cassette Voice...
Kustom Eyewitness VHS stops recording randomly.
The tape is not being pulled through the mechanism properly, and/ or the take up reel is not turning.
Motion is initiated by a motor and transferred by means of belts and pulleys to a clutch and drive assembly, which drives the reels. If any of these slip, the reels will fail to turn. I would replace the belts, idler and clutch assemblies and make sure the pulley and reel surfaces were extremely clean/
May 02, 2017 | Panasonic Televison & Video
Capstan motors of Teac X7 rotate only manually (very stiff)
Allied electronics still has these small motors. They probably won't have the same part numbers though. You will need the printed information from the motor as well as accurate dimensions for an accurate comparison.
Good Luck.
Dec 15, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Reel to reel tape payer
i changed the main drive belt on a reel to reel stereo tape recorder model no A1340 serial no 3642 there is a small wire arm under the play/ record head platform . I believe its the record switch . the arm is not straight looking at machine the arm is straight from switch and go at a 45 degree angle then turns straight and then angles up about a half inch or less . i need to know how to replace this arm ( switch) back into the the head platform so i can start using this recorder
do u have rhe service manual for this machine if so ca i get a copy ?
thanks
Arthur Hathaway
Nov 20, 2008 | Audio Players & Recorders
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
AG-DV2000
If you are seeing tape collect inside the unit, the takeup side is not functioning correctly. This may be as simple as a belt change or idler change. This is not a repair I would suggest that you start with. The alignment of the tape is critical to proper functioning. I would geuss that the "link support mech" is probably just the belt/idler assembly or it is a "mode" switch. In any case, this unit should be sent in for repair. As part of that repair, the conformance to industry standards.
Dan
May 12, 2008 | Panasonic AG-DV2000 Mini DV VCR
94 people viewed this question
 Grubhead
Grubhead
