Question about Sharp Audio Players & Recorders
I have the Sharp compact disc SC-9000av, the disc player picks the disc up but doesn't play
There is a small round disc but I don't know what it's for
ginko
  • 19396 Answers
SOURCE: compact disc player, put disc
Ensure first that there is no disk stuck inside.
If there is a disk stuck inside, try pressing repeatedly the eject button while you power up the unit. Do this a couple of time.
If there is no disk inside, or you get this same problem with all disks, then the lens are dirty, try using a lens cleaning product like the ones here.
Posted on Oct 15, 2008
SOURCE: sharp MD MT-80H(S) not playing sony minidisc 80
I had a similar problem after not using player for several months - "Can't read" message displayed every time I put a recorded minidisc in the player. Seem to have solved it (maybe only temporarily) by opening the player, inserting little finger in at the righthand front and sliding movable mechanism from side to side. It looks to slide on a bar which had maybe picked up dirt or damp. Also tried blowing a warm hairdryer into the slot for a minute or two (take disc out first!) to remove any damp. Working OK at the moment.
Posted on Oct 02, 2009
  • 3 Answers
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Posted on Apr 24, 2010
SOURCE: bd hp210 will not play disc (sharp)
I have the same problem but I did download the updates for both my Sony and Sharp Blu Rays and Avatar played wonderfully but unfortunately a few days later both players stop playing all Blu Rays. Has anyone had the same problem?
Posted on Jun 16, 2010
caroldon
  • 17130 Answers
SOURCE: Hi Last night I was listening to my disc player
Not to worrry , but there is a sliding button, knob that makes the set pause and called as HOLD. All you need to do is to slide the knob back,look at teh side of the door/set. please look carefully even if the pause is pressed twice.
I am sure you will find this out and continue to enjoy music during your treatment. I wish you luck and my prayers for a good treatment. Good day
Posted on Jul 15, 2010
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
What means shuf
That's short for "shuffle". In shuffle play, the player randomly picks a track from the CD to play, so you don't know which one is coming up next. On some Sony models with multiple-CD players, shuffling also randomly picks one of the discs as well as a random track. I don't know if yours is one of them, though.
Sep 11, 2011 | Sony MHC-GX450 CD Shelf System
Will not play or burn cd or dvd
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Mar 23, 2009 | Pioneer (DVR-106D) DVD±RW Burner
Sharp MD MT-80H(S) not playing sony minidisc 80
Jan 19, 2009 | Sharp MD-MT80H Personal MiniDisc Player
APEX AD-1115 DVD PLAYER
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Aug 25, 2008 | Kenwood DV-6050 Multi-disc DVD Player
CD Player Problems
Hope this may help;
Regards,
VOTIT
Aug 17, 2008 | JVC MX-KC58 Shelf System
Sharp cd-ba1600 door won't open err 0201 displayed on screen
Hope this may help;
Regards,
VOTIT
Aug 01, 2008 | Sharp Audio Players & Recorders
Aiwa NSX-SZ10, reacts to all hand controller commands BUT, CD unit will not play. All discs checked for clenliness etc.
Hope this may help;
Regards,
VOTIT
Aug 01, 2008 | Aiwa Audio Players & Recorders
NAD 330 CD player plays intermittently
Hope this may help;
Regards,
VOTIT
Jul 30, 2008 | NAD Audio Players & Recorders
Denon adv-500sd will not play discs!!
hope this may help;
Regards,
VOTIT
Jun 11, 2008 | Denon DHT500SD System
22 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
