I have a W21 Casablanca remote for a Casablanca Stealth fan. I bought this fan in 1994. The remote eats batteries and I have to replace them every other week now. It started acting up like this about
Casablanca told me to replace the remote with a new model and replace receiver in fan
SOURCE: Remote to fan won't work
Try this link for the ceiling fan remote it should be remote style M. I want a spare so I found this web page (page down)http://www.eceilingfans.com/ceiling_fan_remote_controls.html
Posted on Mar 23, 2008
IrishDruid
  • 2712 Answers
SOURCE: D12-300 receiver
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
MN_Jack76
  • 45 Answers
SOURCE: fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Posted on Oct 17, 2009
SOURCE: Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Posted on Dec 30, 2009
How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
Casablanca stealth
Sounds like you need a new receiver.
Jul 19, 2014 | Casablanca Fan 3245A STEALTH® Brushed...
Casablanca stealth fan scraping noise
center of blade bracket mounts scrapping fan housing. Grasp blades and wiggle or shake them to make sure their not cockeyed. Turn it on then to check it.
Apr 13, 2014 | Casablanca Fan Dryers
Casablanca fan-how to replace flywheel?
You'll need a special tool to take it off. Check www.casablancafanco.com for the nearest service center.
May 07, 2013 | Casablanca Fan Stealth 3211T Ceiling
Casablanca stealth fan light scrapes against blade surround
There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
Jun 03, 2010 | Casablanca Fan 3245T Ceiling
Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
Feb 15, 2010 | Casablanca Fan 3245T Ceiling
Casablanca Stealth Fan - Unresponsive To Remote
I fixed this myself by upgrading to an Advan Touch unit. Details here: http://www.casablancafanrepair.com/HTMLFiles/ do_it_yourself/ComfortTouchCommonRep/CTToItConvert6-12- 07Web/SM_CTToAdvanConvert_P1.htmI purchased the P-RMM CT to AT Converts Comfort-Touch to Advan-Touch upgrade kit from http://www.fanmanlighting.com/shop/pc/viewPrd.asp? idcategory=56&idproduct=966The fan man was helpful and my parts reached me in 2 days, normal shipping!
Jan 02, 2010 | Dryers
Fan won't go on
Aug 07, 2008 | Casablanca Fan Televison & Video
Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Jun 10, 2007 | Casablanca Fan 3245T Ceiling
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
