Question about Tablets & eReaders
My vimicro tablet has black screen / doesn't charge or reset
Why is my icraig tablet model# cmp801 not booting up after doing a system reset? The icraig screen comes on but then a black screen after that!
you can give it voice commands by pressing the mic top left corner I told mine to reset and it did it. let it charge up good then turn it on and look for the tiny microphone. say reset and let it do its thang
Dec 24, 2016 | Tablets & eReaders
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 23, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Archos arnova refurbished 7k G3 tablet frozen on ARNOVA screen
i had same problem with my gadget,i replaced the battery.and have it checked to make sure no reformattingg needed
Feb 04, 2014 | Archos Tablets & eReaders
Tablet froze and now doesnt restart
Leave your tablet charging for a hour minimum. The battery might be so dead it has no power to start up at all. You get in to recovery mode do restore to factory settings.
Jun 02, 2013 | Coby Kyros 716829701508 Tablet PC
Klu LT1041 tablet by Curtis screen went black and now will not turn back on
My son put a 9 point lock on his tablet and does not know the unlock pattern. I have done the reset button so many times and need to get back to the factory settings. Can some one help me figure this out? It has been locked for 4 weeks and im loosing my mind trying to unlock it.
Apr 05, 2013 | Tablets & eReaders
AgpTek android 4g tablet charger doesn't charge my tablet !
This solution worked for about a couple of months, but now I'm looking for a replacement power supply also. I wiggled the tiny adapter plug while it was inserted in the tablet and found that it would make contact at a certain angle and pressure. So I got a long fat rubberband and used it to make proper contact by rigging it diagonally, across the tablet. Be careful as too much lateral pressure will bend the plastic sleeve of the contact and render it useless. My theory is that the original problem was partially caused by using the tablet while charging and thus damaging the plug. Although this is a persistent complaint / problem with AGPteK tablets. Mine didn't even last 6 months.
Dec 25, 2012 | Brainydeal Agptek 7" 1.2 Ghz Tablet Pc 4gb...
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Tablets & eReaders Logo
13 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
