Question about Nokia Lumia 1020 AT&T Unlocked White
Lumia 1020 screen
Sensitivity of screen
How to get all my data back from my broken Nokia 1020? Can't access my phone because of damage screen. Thanks
take it to a phone repair shop and have a new screen fitted
before you have it done have the repair shop assure that the screen is the only fault
Sep 08, 2015 | Nokia Lumia 1020
How do I unlock at&t lumia phone?
You can use www.ipmart.com
Magicunlock.com
Is online unlock
Mar 04, 2015 | Nokia Lumia 1020
How do i unlock my nokia 1020 when the screen is broken
Do you want to unlock your Nokia 1020 from network lock ? If so, use unlock code to unlock it . You can get it from any of the online vendors like TheUnlockArena.com to unlock it .
Dec 02, 2014 | Nokia Lumia 1020
Nokia Lumina 1020 locked on Optus Australia
Hello. Do you want to unlock your Nokia Lumia 1020 from Optus network restriction? If so, You can unlock it safer and easier using unlock code. You can get the unique unlock code for a Nokia Lumia 1020 from Unlock-Zone.com at affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch on your Nokia Lumia 1020 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 1020.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 1020 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 1020
Nov 20, 2014 | Cell Phones
HI could somebody please help me unblock my IMEI number -358354050069128 its a nokia lumina 1020 on telstra in australia ,
Unlock Telstra Australia Nokia Lumia 1020
to use any where in the world with any supported service provider likeAT&T, Straight talk, T-mobile, Vodafone, Personal, Claro, O2, Digicel, Telcel, Orange, Telenor, Optus, Tele2, MTN Rogers, Fido, Chatr, Bell, Virgin, Sasktel, MTS, PC telecom, Tbaytel, Telus, Koodo
You can request the code by submitting your imei
@http://www.WorldGSMCodes.com
Your phone will also keep working with your current lock to service provider.
Take Your Telstra Australia Nokia Lumia 1020 with you on vacations and use the local service provider sim card in your phone and save roaming fees.
Telstra Australia Nokia Lumia 1020 Unlocking Instructions
1: Turn on phone with Not Accepted SIM card.
2: A menu will pop up to Insert the code.
3: Insert the provided code and press OK
4: Device is now unlocked.
After Unlocking Telstra Australia Nokia Lumia 1020 will work with
Also any where in the world with any Supported Carrier
*Supported carriers can vary based on your locked to carrier and your region, please confirm with your service provider, before placing order
Your phone will be permanently Unlocked,it will not erase your contacts or any data from your phone.
Nov 19, 2014 | Nokia Cell Phones
How to unlock
HI if you want to unlock your Nokia lumia 1020 mobile from network lock then code is the best solution to unlock it .You can purchase code from sites like WickedUnlock.com for affordable cost.You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ...
Jul 24, 2014 | Nokia Lumia 1020
How to unblock a Nokia Lumia 1020
Unlocking Nokia Lumia 1020 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Nokia Lumia 1020 You need to provide IMEI number of Your Nokia. Type on keyboard *#06# or remove battery from Your Nokia Lumia 1020 to check IMEI number. IMEI is written on the information label.
To unlock Nokia is required choosing network where phone was purchased. You need to also type correct IMEI of Your phone.
Selecting the correct network and the country is very important. By choosing wrong network You will risk receiving wrong unlock code.
How to enter code in Nokia Lumia 1020 ?If we have blocked counter we need to enter code or reset counter using USB cable by program below
How to enter Unlock code RESET COUNTER to nokia using USB cable
Code #pw+123456789012345+1# type in the following way:
1. Turn on the phone without sim card
2. Select character # on the keypad
3. Characters p, w, + get by choosing few times STAR *
4. Press # button to approve code
5. Message "SIM restriction OFF" appears, Your phone is now unlocked
WARNING!!!
You have only 3 attempts to enter the code. The last failed attempt will block the counter.
Gopakumar Gopalan Google
May 16, 2014 | Cell Phones
Can I change the operating system in my Nokia 1020 from Windows 8 to the latest version of Android?
Phones such as the Lumia 1020 only support the Windows Phone 8 platform, and can be updated to the upcoming Windows Phone 8.1 operating system. They do not currently support the version of android that the Nokia X has.
Apr 08, 2014 | Nokia Lumia 1020
My screen went black
Take battery out. Unplug notebook. Hold power button in for about 20-30 seconds to discharge residual power. Reinstall battery. Plug in AC adapter. Unit should come back to life. If it does not, it may have an issue with its chipsets that will require professional repair.
Oct 22, 2013 | Computers & Internet
Nokia Lumia 1020 AT&T Unlocked White Logo
44 people viewed this question
Top Nokia Cameras Experts
Steve
Are you a Nokia Camera Expert? Answer questions, earn points and help others
