Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
The washing machine has a very bad musty smell.
  • 29 Answers
The drain plug needs to be cleaned before it burns up your pump. There should be an access panel at the bottom that you have to remove the screws from and drop the panel down and then you should find a cap that you twist and pull that is the filter. Make sure you have something underneath it to catch the water or you will have a mess.Good Luck
Posted on Jun 15, 2009
SOURCE: Musty smell in washer
We had the same smell. It was so bad you could smell it when you came into the house. We switched to powdered detergent and the smell went away. If you put your nose down by the rubber seal you can smell it a little, but I consider the problem fixed!
Posted on Oct 25, 2008
SOURCE: musty smell in washing machine
I tried all of the suggestions and nothing worked, So I took apart my machine to find the source of the problem. There was a ring of black mildew that was the source of the smell I clean it and that took care of the problem!!!
Posted on May 02, 2009
  • 10865 Answers
SOURCE: Smell coming from inside washing machine. Not musty.
This is a fairly common problem that often arises when the majority of washes are done with cold water.
Do what is called a maintenance wash where you set the machine to run with hot water and maximum fill of water. Add one half cup of baking soda and let it run through it's entire cycle with absolutely no clothes in it.
After it completes its full cycle check for that bad odor. If it is fully gone wonderful. If it is half as bad do a second maintenance wash.
If the maintenance wash doesnt seem to help at alll get back to me and I will make another recommendation.
Posted on May 25, 2009
marka19
  • 1430 Answers
SOURCE: drum smells
Open the door and run your hand deep inside the door seal. It probally has a slime around it. You can clean this with a bleach water mix. You might need to pull the seal somewhat inside out to get it real clean. Then run an empty load to flush it all out. Here is a link for replacing the seal or spring clips if you pull one off. http://appliancehelponline.com/washerdoorseal.html
Posted on Jul 07, 2010
Testimonial: "had already run a boil was to no avail. however after washing the inside with bleach solution and leaving overnight it seems ok again."
MNTECH
  • 1543 Answers
SOURCE: How to get rid of smelly washing machine? Has a
Use a washer cleaner like Affresh, then use only one tablespoon of soap per load to prevent re-occurance.
Posted on Nov 10, 2010
Clothes smell bad when they are dried
Sorry but having no idea what make ,model equipment you use we can not suggest a fix .
Mar 16, 2016 | Washing Machines
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Washer smells bad - musty
smell are normally due to 3 culprits
low temp wash , liquid soap , moisture
affresh washer cleaner may be worth a try
video
May 07, 2010 | LG WM0642H Front Load
Musty smelling washing machine
www.smellywasher.com you can order here to take care of that problem!
Jan 17, 2010 | Whirlpool LSR5132PQ Top Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
390 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
