Question about Eureka Rally 2 Canister Vacuum with Automatic Cord Rewind, 980A
My Eureka Rally 2 Cannister Vac randomly stopped working
I was vacuuming out our hall way and it randomly shut off. I noticed that the bag was extremely full so I changed it. Now that I changed it, It still wont turn on? any help?
  • Kelsey Beson
    Kelsey Beson Mar 26, 2014
    where do I find the brush role? and the model is 980, type AEZ-1
I am going to tell you this it is trash the motor went out buy a new one
Posted on Mar 28, 2014
  • 1462 Answers
SOURCE: Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Posted on Mar 31, 2007
  • 55 Answers
SOURCE: have eureka victory upright bag
There are four holes on each side of the top of the hood. There is a screw on each side, inside one of those holes. You have to take those two screws out to remove the hood.
Posted on Nov 26, 2008
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
Posted on Jan 06, 2009
SOURCE: how do i change the
I had the same issue and found the manual online. The answer is on p. 10. (Could they make this more difficult??!!)
http://www.eureka.com/service/manuals/70262B.pdf
Posted on Mar 25, 2009
SOURCE: no suction on my eureka boss smart vac. The belt
I know this is an old question but this is a good vac and maybe I can help somebody else some day, wish I'd figured this out a couple months ago when this problem first started. :} Anywho, this is another option from an amateur; I don't know the right terms but here goes: Right below the yellow flow knob (Floor/Hose) are the tops of two hoses, one to floor beater, one leading to hose. There is a sort of black clip holding these in place. Open it up, it hinges toward the front of the vacuum. On the back of the vacuum to the right of the lower cord wrap is a gray screw-looking thing, with little pix of locks imprinted above - one locked, one unlocked. Turn the screw toward unlock. Take the top of the black tube that leads to the hose and maneuver it out of the hole it's in, and you may find your clog in the top there. I found just a handful of dog hair, leaves and sticks stuffed in that tube but it was dense enough to stop flow to the hose. Removing it fixed the problem completely.
Posted on Jul 20, 2013
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
Cannister vacuum works for minutes then shuts off
If it's new and under warranty, contact the manufacturer. If you change anything on it, your warranty will become void; therefore, I would contact the manufacturer for replacement and if you paid with a credit card, contact them after you have made your statement to the manufacturer so you can take action for a credit should you prefer to send back to seller and get a refund from your cc company.Jimmy
Mar 10, 2012 | Eureka 965 Bagged Canister Vacuum
How to replace bag on eureka rally 2 vaccum
where do i get anothe dust bag holder??
Jan 02, 2012 | Vacuums
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
Since I replaced the bag in my Eureka Rally 2 (this was the first time) the suction has not been working well. Could you please tell me what I could have done incorrectly. Thankyou
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Mar 28, 2011 | Eureka Vacuums
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
Dec 25, 2010 | Eureka Vacuums
Eureka Rally 2 Canister Vacuum with Automatic Cord Rewind, 980A Logo
352 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
