Question about Toshiba Satellite P755S5215 PC Notebook
Toshiba p755 wont start with adapter
Will not charge, adapter plugged in still no power
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
The board will need to be checked for problem if not charger or battery
Posted on Mar 26, 2014
The battery run down without no use and when you boot it, it will shut down by it self, and is booting slowly.
If this is a new laptop, you need to migrate your data off it and get it replaced. Something is draining your battery, or the battery is bad. Keep the power cable plugged in and save what you need. Contact your vendor customer support for a replacement.
Mar 17, 2015 | Toshiba Satellite P755-s5320
Automatic on toshiba p755
Not sure what system you are talking about. If you are saying that your Toshiba is automatically powering on then you may have a feature called wake on LAN enabled. Press the key at power on to go into your setup menu, look for the wake on LAN (sometimes called magic packet) feature under power control and disable it.
Feb 11, 2014 | Toshiba Satellite P755-s5120 Core I7 Pc...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Wont turn on and wont charge plug light is blinking
Power darin the computer
1. remove the battery
2. remove the AC Adapter
3. press and hold the power button for 1 minute
4. once done plugged back in the battery and adapter
5. turn on the computer
6. if it does not work call the tech support for possible mechanical failure.
Hope it helps.
May 12, 2010 | Toshiba Satellite A20-S259 Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
Charging issues with a toshiba A215
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 11, 2009 | Toshiba Satellite A215-S7422 Notebook
No singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
Aug 07, 2009 | Toshiba Satellite M105-S1021 Notebook
Open Questions:
Toshiba Satellite P755S5215 charging issues Ok, to be blunt and straight to the point, my laptop will not charge "while it is on". It must be either off, sleep, or in hibernate mode for it to charge. A pinkish light flashes if it's not fully charged when on. I bought a new charger, a new battery, still the same issue. I updated the Bios and continue looking for updates to solve this problem, but nothing helps. I'm good with electronics, but I just can't seem to get this laptop to charge. So for the last year, all I've been doing was making sure the battery stays fully charged, because if I don't and I don't notice that the battery is being drained then I have to wait HOURS for the battery to charge all the way or I just switch the next battery til something goes wrong with that. I also noticed that when on the computer the battery would start draining, and it seemed like it was reacting to me using softwares on my computer. Not sure which softwares it could be though. But I've basically tried everything I could think of. I did have a little issue with the power port, but I fixed that myself. I took the the laptop apart and put the port back in place because it was loose. My original laptop charger had broke and I struggled keeping the battery charged, but I didn't have this issue until I got a new charger if I remember correctly. I don't have enough money to pay Toshiba to fix it, they gave me the run around when I called them which made me feel like I couldn't trust them when they didn't even know what they was doing or talking about. They talked like they were beginners and told me everything a 8 year old child would know. Check the battery, charger...still nothing? Send it in, we'll look at it, oh and we're not liable if everything is erase. I don't trust none of that. Your property is not safe with a company who says your memory may be erased. If that's the case, then you contact the owner and let him know, you may need to erase the harddrive before doing so, and they'll let you know, go ahead or not. I wouldn't recommend Toshiba laptop products, because I've seen a lot of ppl complain about their customer service and how bad the products are messing up. How do you not know how to fix your own products? A couple of people have the same problem as I and they said Toshiba said they're not sure on what the problem is and to send it in. If it's not fixable then I'll just sell it and never buy a Toshiba laptop again, and recommend people not to buy any of their laptops. I don't want people to go through the same situation I am.
Jul 13, 2012 | Toshiba Satellite P755S5215 PC Notebook
Toshiba Satellite P755S5215 PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
