Question about Sewing Machines
Needle hits something and breaks on my pfaff 2140
When lowering the needle it slides to the left a little instead of going straight down, i was on zig zag when it started breaking needles.
    New Friend:
  • 46 Answers
Check that the selector button is fully down on the straight stitch. It should matter if the needle is straight and you have a zig zag plate on the machine. The other option is that the needle is bent and a new one may fix the problem. They dont need to be out by much but you said you had broken needles so it might even be a timing problem and hitting the bobbin case rather than taking the thread to be picked up by the racer.
Posted on Mar 28, 2014
SOURCE: no zig and cotton keeps breaking
Make sure you have a new sharp needle installed for both problems and sometimes you need a particular kind of needle for the fabric. Also some machines don't deal well with 100% cotton thread. For some reason it gets caught up in the machine somewhere and breaks. Gutterman and Metrosene make excellent although slightly more expensive threads. Coats and Clark thread is good too. They make an all cotton thread but it doesn't come in as many colors. If you have the old spools of cotton thread from Walmart, just use them for topstitching if you need the color. Other wise, use them for hand stitching or throw them away. One more thing that I can think of off hand, one of my machines does not like lining fabric. For some reason the thread breaks if I stitch really fast. If you have to use that thread, you may try sewing slowly. One more thing, when was the last time your machine was serviced? This can make a huge difference if it's been awhile and you use the machine a lot. Good luck. Hope any of this helps.
Posted on Apr 02, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 2976 Answers
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
  • 1116 Answers
SOURCE: Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Posted on Feb 22, 2010
SOURCE: machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Posted on Mar 21, 2012
How do I change needle position on my Pfaff 2044
Use the zig zag adjustment while in straight stitch to move the needle position to the left or the right
Feb 10, 2015 | PfaFF Sewing Machines
Keeps breaking needles
Slow down and watch what you sew over.
No needle is going to sew through the metal part of a zipper.
With many layers of fabric you have to slow down. If you have multiple layers of a thick fabric you may have to resort to using the hand wheel to get through the layers.
Another tip would be to not pull on the fabric. The machine is capable of "feeding" the fabric at the rate it requires. When sewing with many yards of fabric the weight of the fabric may create a pull on the needle. If the needle is pulled so that it no longer goes through the need plate properly it will hit the metal of the needle plate and break. Instead rest your hands on either side of the fabric and gently steer the fabric. Do not pull it out of the back of the machine or shove it into the needle. With large yardages wad up the fabric around the machine so that the weight of the fabric isn't causing strain around the needle.
One other tip. If you have a needle plate in your machine that only supports straight stiching, that is one with a needle hole that is just big enough for the needle to move up and down, and you switch to a zig-zag stitch, you will break the needle. Most factory installed needle plates have a needle hole large enough to support the largest zig-zag that the machine can support. But some machines have custom needle plates (for quilting) that only support a straight stitch.
Dec 08, 2014 | Sewing Machines
Singer serger 14u
Sounds like your needle is hitting the needle plate instead of going through the tiny hole down to the bobbin. Try using the handwheel slowly and watch. Or perhaps the needle is hitting the bobbin case. Something has been knocked off the straight I think. Has your machine been dropped or dmamaged?
Oct 15, 2013 | Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
I can only sew straight or very little width stuff. The needle hits on something when it moves to the left.
I suppose you already have the needle position in the middle. Try selecting the widest stitch set on the right side, See if it hits anything and if it's the same distance as the left. If it's not then you'd need a service person do a complete alignment, timing and other related service to zero your machine.
Oct 04, 2009 | PfaFF Creative 7570
How do I adjust the timing on my SINGER CG590C
If you have a zig-zag machine check to see if the needle is set to the correct position. If you are trying to zig-zag, be sure you have the wide holed throat plate on.
Jan 27, 2009 | Sewing Machines
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
