Question about Garden
Flymo tines how do i change the tines
  • 708 Answers
What are you referring to as tines, it sounds like you are working on a roto-tiller. I will need more info as well. Model# Unit type-ie. lawnmower. Are talking about the blades? If so the there is a large nut that bolts the blade to the lawnmower. Remove bolt by holding blade with gloved hand and long breaker bar. You can strike the breaker bar with a three pound hand sledge to break it loose. Replace or sharpen blade as necessary. Apply grease or never-seize ti threads on crankshaft, spin on the bolt and tighten with long breaker bar. Good luck!!!!! If this is a tiller, then let us know, ok?
Posted on Mar 29, 2014
How to change blade on a flymo L470
there is a bolt that holds it on. just googled it
Jun 08, 2016 | Garden
How do I change the tines
You have not shared which model and make of tiller you have, but many of them have a set screw or two holding each tine on.
You would need to loosen the screws, and maybe polish the shaft with sandpaper and oil it to get each tine off in order.
Some tillers use a different method of tine installation, since this can be patented or trademarked.
For example, some have the tines permanently attached to the shaft, so the whole shaft must be replaced as a unit.
God bless your efforts.
May 12, 2016 | Garden
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Flymo instruction manuals
www.flymo.com/uk/robotic-lawnmower-support
www.flymo.com/uk/contact-us
Jul 14, 2014 | Garden
Flymo instructions
OK, I checked out what youy have I have never changed the before but it looks like the whole spool is replaced by removing nuts on end of shaft. Then pull shaft out and replace with new spool. Hope this helps.
Mar 26, 2014 | Garden
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
Switch for hover mower 300mm 1250w
Hi and welcome to FixYa, I am Kelly.
Can we get a Make and model number please? I am searching for any brand of hover mower that is 1250W at the moment and there are at least 3 different brands:
This is the Flymo manual:
http://www.shop.flymo.co.uk/images/mediator/397/oipl2002_p0201018.pdf
This is the switch for the Flymo Hover mowers:
http://www.espares.co.uk/part/lawnmowers/flymo/turbo-compact-330/p/1116/283/116/402362/1136941/8a-250v-lawnmower-switch.html
This was my best mind reading guess. If this is not your brand then help us help you by responding with a make and model number please.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Garden
How do i change the leaf blower to a leaf ******?
Hi and welcome to FixYa. I am Kelly.
You can download your "Operator's Manual" here:
http://www.shop.flymo.co.uk/images/mediator/397/1)%20service%20manual%20(twister%202500%20(9660589-01)).pdf
The answer to your question is in the manual on page
4 of the pdf file WITH pictures.
Thanks for using FixYa.
Kelly
Apr 07, 2010 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
