Question about Xerox 6180MFP/N Printer
After resetting the nvm on an xerox phaser 6180mfp it does not recognize the transfer unit
It does not recognize the transfer unit and it is driving me crazy. i even removed and changed the transfer unit for a new one but still does not recognize it. and before i resetted the NVM on the printer it worked properly
  • dann jackson Mar 29, 2014
    Hi agustin zamora, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    what is your error code?
  • agustin zamora
    agustin zamora Mar 31, 2014
    hi, dann. The problem is that there is no error appearing on the screen, it just says insert transfer unit. however, i have had a look at the main menu by pressing and holding the up and down buttons when turning on the printer, i looked at the motor set and got access to the nvm settings and i found out that there is no memory in the nv memory. I would like to know how can i restore the memory of the printer, because apparently everything else apart from the nvm, is working perfectly. thank you
  • 2072 Answers
SOURCE: Xerox phaser 7400
There really isnt an easy way to do that.
The transfer belt assembly starts off with a fuse on it to blow immediatly on install, and a counter that is internal so that it will end of life and have to be replaced. It's really not a convience counter but an obsolence counter.
Posted on Mar 06, 2008
SOURCE: Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Posted on Sep 15, 2008
Arius
  • 446 Answers
SOURCE: 9-358 error is there a reset nvm
no! there isnt, you need to replace this in order to reset the info inside, you can refresh the nvram but the info is still there
Posted on Sep 22, 2008
  • 8 Answers
SOURCE: NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Posted on Dec 29, 2008
SOURCE: Hello, after a NVM reset my ADF stop working.
Sorry to ask bu how did you enter NVM or better how do you reset nvm plz reply !!!
Posted on Feb 24, 2010
Why phaser 7760 toner cartridge not recognized
You will need to contact your local Xerox concessionaire for further information. It can be a faulty CRUM chip on the side of the toner cartridge (very un-likely) or if your machine is quite new then I've seen an NVM location needed to be updated. (slim possibility)
Xerox Concessionaire is the best course of action.
Good Luck.
Jul 02, 2014 | Xerox Phaser 7760/YDX Laser Printer
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
How to reset the password on xerox6180MFP
According to the service manual, it says to hold the Menu button during power on to reset the password to 0000
Apr 20, 2011 | Xerox Phaser 6180MFP Scanner
Phaser 6180MFP has error code 133-290 how to correct, and what is it.
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Oct 04, 2010 | Xerox 6180MFP/N Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Transfer Life Low Error on Xerox Phaser 6180
That error is caused when your transfer roller is out of life.
The transfer roller should be in front of the machine when you open the front cover. It will look like film material it is held with two plastic locks one on the right and on the left .
They maybe be colored yellow or blue sometimes.
(800)367-4836 <-company sells refurb and brand new ones. hope this helps. They will also give you free tech support.
Dec 23, 2009 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180MFP i have replaced toners
There are a couple of possibilities here.
Is the printer on a 'page pack' contract ?
Are the toners really chipped for the printer you have ?
There are 8 printers (including the multifunction variants as yours is) that take a SIMILAR cartridge.
They vary in capacity and chip. Some remanufacturers don't realise and have been sening out cartidges for these with the wrong chip fitted.
There has also been a bad batch of chips (a while ago now).
The solution is quuite simple, contact your supplier tell them what the problem is (error message etc) and they should be able to check the cartridge in their test printer (a GOOD remanufacturer will have a test printer for each of the cartridges they produce - how could they test their product otherwise !!).
Oct 09, 2009 | Xerox 6180MFP/D Printer
Xerox 6180MFP/N Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
