Question about Motorola Symbol Computers & Internet
Simple com port emulator
Need a Driver for the DS3478 Scanner to work with Windows 7 64bit system.
    New Friend:
  • 82 Answers
Sorry, no can't do.
You have to go back on OS or search another port-based device
Posted on Jun 10, 2014
3 Suggested Answers
  • 5 Answers
SOURCE: Datalogic Touch 65
probably your scanner is faulty..
Posted on Aug 15, 2008
SOURCE: COM Port issue with 4600 and 4800
You tell Pip to put back on the K/B wedge and make programers - u know program it to work [8^) lol
sorry for the false positive
Posted on Sep 17, 2009
Where can I to get the barcode programming for Symbol Com port Emulation?
Miren
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Dec 02, 2014 | Symbol Computers & Internet
Wher can i found Simple COM Port Emulation USB driver version 1.8.6
Have your tried the driver provided at
www.driverscape.com/download/symbol-usb-com-port-emulation
It says tis 2.33mb. Even if it turned out to be a driverscanner, simply install and wen it find the driver you are looking, use the ID to search for it on google and if it can installed directly.
Good luck
Nov 14, 2014 | Symbol LS2208 Handheld
Driver emulation for windows 8
You may never get it to work unless the scanner manufacturer releases a driver for windows 8. Go to the scanner's web site to see if one is available.
Jan 23, 2014 | Visioneer OneTouch 7100 Flatbed Scanner
DOWNLOADED THE DRIVES FOR WINDOWS HP AND WHEN I OPEN IT UP TO USE THE SCANNER IT SAYS NOT INTIALIZED. SCANNER NOT FOUND. AND IT IS HOOKED UP WITH PARARELL CORD.
It's due to a port protection in microsoft systems after windows NT, old drivers can't use some hardware connected to some ports (ex: pararell port).
You need to set up your system so drivers can communicate with the hardware ports.
In this case you can use dlportio.dll and follow the next steps:
1) Open the zip file. 2) Copy the file dlportio in one of the following places a) c:\Windows\system32 b) c:\Windows c) The root directory of the affected application.
If it still doesn't work:
3) Reinstall the driver.
If problem still persists you can install some kind of DOS emulator, commonly used to play old abandonware games.
If you need more assistance please leave a comment.
Regards.
Oct 22, 2010 | HP Scanjet 4400c Flatbed Scanner
DEAR SIR I HAVE COMPAUTER HP COMAQ DC 7900 I WORK WITH SOME PROGRAM WORKING IN DOS .. THAN I NEED INSTALL DOS OPERATING SYSYTEM THE COMPUTER DON'T RESPON ... ALSO THE COMPUTER DON'T HAVE LPT I BRING CARD...
the best way to do this is probably use windows and run dosbox for windows. What it does is it emulates DOS and lets you run any program that requires dos. Because your computer doesnt have a LPT port. and nowadays only drivers for dos or newer operating systems come with the card. installing the driver in windows then running dosbox, it will see the LPT port.
you can get it here
http://prdownloads.sourceforge.net/dosbox/DOSBox0.73-win32-installer.exe?download
May 04, 2010 | Computers & Internet
I cannot open ports TCP/UDP for eMule using router 2Wire Infinitu
You need to portforward your router to accept emules port number/numbers. Go to portforward.com. look up your router and follow the instructions. It's pretty easy.
Nov 28, 2008 | Xincom XC-DPG602 Router (XCDPG602)
Scanner symbol ls3070-i100US
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Oct 06, 2008 | Computers & Internet
Driver for astra 3450 scanner
The Umax Website only shows up windows xp drivers and below, unfortanatly it looks like if there is a driver for windows vista you will have to contact them directly and order the driver software.
I have search a while on this to try to find a substitue driver but seems nothing is available for your unit.
The only other solution would be to find a Vista Ready Scanner.
besides running a windows xp emulator on your computer
Aug 09, 2008 | Umax Astra 3450 Flatbed Scanner
I have a Memorex U48 Flat Bed Scanner and have bought a new compouter with Vista. I need a driver download to work with Windows Vista. Thanks jreowens@aol.com
get the winXP driver MEMu1.50 (still available), there are no Vista drivers. Run the installation using WinXP emulation in Vista. You must run the installation as if you are in XP, not necessary when using the scanner subsequently. Now the Memorex 48u works on a Dell Dimension, running Windows Vista Home Premium. Hope this helps. I got the scannner for $14 after rebates at Staples years ago, it won't die.
May 05, 2008 | Memorex MEM48U Flatbed Scanner
Computers & Internet Logo
155 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
