Question about GE X500 Digital Camera
Camera is stuck in the on position
When turning on camera it is stuck on saying imagination at work
Door Open but latch in closed position - HELP!
You need to operate the door release handle at the same time as applying pressure to the latch you can see just inside the door (imagine which way it would move if the thing was working as designed), the tech has possibly simulated a door closed position for testing purposes.
Apr 22, 2010 | Neff 24 in. S5456 Built-in Dishwasher
My focus lens is stuck in the open/out position. i cannot take photos, the screen says unable to focus. help!
It sounds as though the battery is low and the camera is faulting and has become "stuck" because of it.
I would suggest you try this first to see if it is.
Turn the camera off, take out the batteries and then re-insert with new ones or charge the old ones before you re-insert them. Make sure the batteries are fully charged.
This "should" jumpstart the camera back to the original configuration.
If this doesn't work please post back.
Hope that helps!
Nov 09, 2009 | Fuji FinePix S3100 Digital Camera
Lens stuck outside. Sometimes says "access" on lcd.
Try these troubleshooting steps and check if it help to resolve it.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Press the Menu button on the Camera.
2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
3. Then, select the Initialize option to OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Aug 31, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
There is a strange sound coming from my camera and vibrations
Hi there.
It sounds like the lens is having difficulty moving into position, cover the lens with your thumb and spray a little WD-40 around the affected area.
With the camera card, take it out, clean the contacts and blow down the slot to remove any dust that may have built up.
Make sure the camera is turned off while you spray it.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
Shutter is stuck on open position
shutter is stuck half way open and when the camera is turned on it says lens error 0x001110000 and then it shuts off
Apr 30, 2009 | Cameras
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Lens
Call 800 730 6597 and we will replace it if it is still in warranty
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Oct 28, 2008 | GE A830 Digital Camera
Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Jun 30, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
My nikon says lens error
my camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Jun 16, 2008 | Nikon COOLPIX L5 Digital Camera
Too much fun... sand in the camera!
Best advise i can give you is to get an air canister at your local walmart or whatever store. use the tube and get in the little cracks with it, try to move the lens in or out a LITTLE while you spray so it loosens the sand enough for the spray to move it out.
Jul 29, 2007 | Canon PowerShot SD1000 Digital Camera
GE X500 Digital Camera Logo
42 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Are you a GE Camera Expert? Answer questions, earn points and help others
