Question about John Deere 2000 7410 47632
7410 JD PTO comes on but shuts off after 30 seconds
Pto keeps shutting off
wadembly
  • 513 Answers
SOURCE: My Johndeere 2510 pto will engage. But you have to
its actually the clutch not disengaging enough for pto to engage or the teath are worn down on pto shaft
Posted on Jun 05, 2009
  • 58 Answers
SOURCE: I have a JD 1070 4 wh dr, when running a brush hog
Reading on line, I see your tractor has a PTO clutch. It must be slipping. It either needs adjusted or replaced. A slipping clutch disc will make a bad smell.
Posted on Jul 28, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
wireguy212
  • 1627 Answers
SOURCE: PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Posted on Oct 21, 2009
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
How come I can't start my John Deere LA115 after
The Reverse Interrupt Override switch is supposed to let you keep the blades engaged while using reverse. Be sure PTO is off and brake pedal is depressed and try to start engine. If it wont start/ wont crank then a switch is stuck or failed or there is a broken wire. Switches that are involved with PTO operation are the seat switch, reverse switch, PTO switch, and RIO switch. The starting system requires neutral ( no reverse activated), brake switch and PTO switch off.
Sep 02, 2014 | Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Why does my John Deere 5425, Pto keeps shutting off?
Check all connectors going from switch to PTO engagement clutch. Check ground wire from PTO. This problem is either a bad connection or a faulty electromagnetic PTO.
May 12, 2014 | Garden
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Engine cutting off after engaging the pto (mower deck) JD 317
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 2000 7410 47632 Logo
693 people viewed this question
Top John Deere Equestrian Experts
JOHN BROWN
Bill Taylor
Bill Taylor
Level 1 Expert
jesse
jesse
Level 1 Expert
Are you a John Deere Equestrian Expert? Answer questions, earn points and help others
