There is no sound coming out of the tv
We have a samsung 42" and one day the volume just stopped working. It can be adjusted from both the remote and manually but no sound comes out.
    Top Expert:
  • Televison & ... Master
  • 26,707 Answers
If the volume on screen can be adjusted, the output stage is possibly faulty. Maybe a fuse link on the audio section.
Posted on Mar 26, 2014
Testimonial: "Thank you so much for your input. Are either of those types of repairs relatively inexpensive?"
SOURCE: vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Posted on Feb 19, 2009
tcobiz
  • 35 Answers
SOURCE: cox universal remote won't control samsung tv ln52a650 volume
This is a tough one, I can come up with possibly 2 solutions, 1 being that if the batteries are low you will sometimes lose partial control of some of the functions on the remote, and if that is not it, then I have another that this one happened to me once, The infrared on the TV was not picking up the volume button I was sitting at an angle, so everytime i sit in that chair everything works but the voulume control i have to point it right at it on direct line and not from the side...Hope this helps...Steve
Posted on Jun 13, 2009
  • 157 Answers
SOURCE: 42 in Vizio TV volume stopped working
you can eithor get the board from shopjimmys.com or hook up surround sound system-and not use tv speakers
Posted on Sep 11, 2009
SOURCE: can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
SOURCE: my samsung ws28a116d remote will only adjust the
To reset the remote so that it works properly again, take the batterys out of the remote, then press and hold the power battery for at least 30 seconds to drain out any power left in the hadnset , then replace battterys and it should work again. We had this fault and this solution worked for us
Posted on Sep 26, 2009
Been having sound problems for 6 months.. At first i could just adjust the volume up and down and it would come back on now it won"t come on at all. picture perfect just no sound. Tryed changing from...
ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
Mar 03, 2018 | Samsung PN58B540 58 in. Plasma HDTV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I just bought a 52 inch samsung my volume does not work on my cable remote.everything else works ok i have to use remote for the tv to adjust the volume. i have time warner
Did you try another time warner remote if yes then this is normal because if on/off works that means the volume function is not coded for the time warner remote because the set is to new.
Jun 09, 2009 | LG 42LC2D 42 in. LCD HDTV
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Samsung ps42
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Oct 26, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung DLP 42" Volume Problem
you might want to get a tech to come and check the service menu and see if some of the audio settings have moved or are miss adjusted as per the mfg. settings
Jun 05, 2008 | Samsung DLP HL-P5663W 56" TV
I have no audio on my 42" Samsung plasma tv
This happened to me also. It had to be taken apart. The audio connector on the motherboard had come lose. Hope this helps.
Dec 04, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
