Question about Coffee Makers & Espresso Machines
Very wet grounds are spilling into the machine
For the last two weeks, the grounds have been very wet and spilling into the machine. There is no longer a solid puck anymore, but only muddy grounds. I have tried coarser (and finer) grind settings, various beans to water ratios, and multiple brands of beans. They have made virtually no difference. On top of the brew group, there is a flapper that ejects the spent grounds into the disposal. Ever since the grounds have been so wet, a lot of the muddy stuff sticks to the brew group, and some of it gets pushed in the opposite direction when the flapper swings back, spilling into the machine. I am comfortable replacing or repairing parts, but am trying to avoid replacing the wrong thing. I have made one prior repair to this machine, when the ball of the pump got stuck in the nozzle months ago.
  • Pietemans
    Pietemans Mar 27, 2014
    This is a DeLonghi Magnifica ESAM4200. It appears that the site did not recognize the model and put this in the general category.
espressodoc
  • 29 Answers
SOURCE: Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Posted on Jul 29, 2007
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
SOURCE: Saeco Odea Giro - alarm light continually slow flashing
I had the same problem. I filled everything up and closed it then took the hopper top and placed a small magnet that fit the circumference of the hopper sensor (I took one off of a refrigerator magnet and it fit down into the sensor) and it immediately went green. Hope it works for you.
Posted on Jun 30, 2009
  • 60 Answers
SOURCE: Gets stuck on Brewing. Tried turning off,
Descale your brewer
Posted on Mar 23, 2010
EsWorld
  • 1618 Answers
SOURCE: jammed brewing unit
Remove the brew unit and check the screen under the red o-ring, find the 2 screws above the top piston and make sure the chamber that leads out to the tube is clear.
Posted on Mar 29, 2010
I have a flat tv on wall but my 4 old wet it with duck on the bottom of tv. Now shows it have lines on side. If let dry with a fan will it work normally help any tip
MOST, electronics should work properly after being wet.. as long as:
1.it was not / does not get turned on well it is wet.
2.it is only water that was spilled on it (NO- soda, milk, juice)
your best bet is to let it fully dry for a week or so, not in direct sunlight, and make sure there is no power running to it.
May 17, 2015 | Televison & Video
Fan stays on till i pull fuse new radiator about 3 weeks ago ck engine lite on now
whoever replaced the radiator probably just spilled coolant on the egine coolant temp sensor on the rad and now its giving a false reading. Its probably reading too hott which is keeping your rad fan on. check too see where the ect is and if its wet or was wet. it might be easy to replace on a truck.
May 02, 2011 | Dodge Grand Caravan Cars & Trucks
My Keurig Single cup sensor won't work. When I set a coffee cup in the craddle it doesn't recognize that the cup is there. Any suggestions?
This happened to me 2 weeks ago. I searched this site and saw no responses, so I want to answer now that I know what to do. Pull out, clean and dry the spill assembly the cup sits on. Dry the open area. Let it set for about a week or two. I live in CA (its very dry here). I was so happily surprised when I tried my Keurig again yesterday - it is working like NEW. I used to work for another small appliance maker so I knew that the sensor had become wet when the spill assembly filled to capacity. Hope you still have your Keurig and this solution works for you too!
Feb 20, 2011 | Keurig B30 Mini Coffee Maker
Water and coffee spilling from Filter Basket onto counter?
We used to have the same problem! try a better brand of coffee filter! It worked for us? Also make sure that the filters are not doubled up!
Jun 16, 2009 | Black & Decker SpaceMaker ODC440B 12-Cup...
Whirlpool LSR7010PQ2 can't spin dry, clothes still wet
If it was spinning slow before the total failure It would be your clutch ,Check your lid switch.
Apr 24, 2009 | Washing Machines
Problem with my 1999/2000 Jetta.
did you over heat her?..sounds like a blown head gasket or ?...water entering combustion chamber from other area..(cracked block, intake manifold leak).....do compression and leak down tests
Dec 31, 2008 | 2000 Volkswagen Jetta TDI
MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Nov 21, 2008 | Maytag PAV2300 Top Load Washer
Phone stopped working
Try to blow dry and then power up.
Sep 02, 2007 | Motorola Mobility RAZR V3
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
