Question about RCA F27648 27" TV
RCA model #f27648 reds missing from picture
Reds missing from picture, replaced by black. I have tried switching cables, fiddling with the tint & warmth. most things that have red mixed with other colors look yellow, green, or blue, but reds don't show up at all. It worked fine a few weeks ago.
    Top Expert:
  • RCA Master
  • 74,136 Answers
It sounds to be a video output stage circuit fault. Check all the solder terminals at its CRT base card, including the solder terminals of the CRT base to the card. Re-solder all the suspected solder terminals by applying a little more fresh solder. Contact any service technician. Check the solder terminals of Red color output transisotor. If needy, replace it with a new one with same number printed on it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
The fault is 'one colour predominant/absent screen'
Posted on Mar 26, 2014
2 Suggested Answers
johnnydiode
  • 647 Answers
SOURCE: Problem with picture color
Magnetized The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 26, 2009
I have an issue with a tv It is a Hitachi Ultravision Directors Series model #55HDV99. It has picture and sound, but the color is not correct. The reds and blues are missing.
Check the connection between your cable box and tv.
You should have five rca cables connected. Red, yellow, and blue. the other red and white is for audio.
Regardless of them passing the eye test. Push on each end to make sure contact.
If that doesn't do it you may have a bad crt, but you are missing red and blue that would be two bad ones at same time. Not impossible. Could just be bad solder connections as well.
Dec 03, 2015 | Hitachi Televison & Video
RCA R2WH74YX58 tint problem
Your green CRT may be going bad, You can get a replacement CRT ( picture Tube) at the following link very cheaply with free instalation instructions.
Sep 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a hitachi 50c20 tv and it has a red tint/hue across the whole screen
Are you using component cables into the TV? It sounds like one of the 3 video cables may have come out saturating the red colors. Check your cabling int he back of the TV, see if you remove 1 by one if that changes the colors. Each cable on its own should have a picture with either red green or blue colors. If any of them are missing the picture then the colors will get messed up when all 3 are plugged in. If you are not using component cables then check the color settings on your TV. Somewhere int he menu of the television you should have something like picture display settings that let you adjust the colors. Check and make sure that the reds are not over configured or the others are not set too low. You may also want to check that your source is proper as well. Check that other sources look okay or if it is with all different connectors/sources that the issue occurs on.
Oct 15, 2013 | Televison & Video
Green tint to picture.
Are you using the componant connection on your tv? If so, check the red, blue and green cable connections on both ends. They carry your
picture info to the tv. The audio is carried by a red and white cable. There should be 5 cables for a componant connection. 2 reds, 1 white, 1 blue and 1 green. I hope I have guessed your problem correctly and this helps you.
Apr 07, 2010 | Sansui HDLCD-1900 19 in. LCD Television
The color is off, no reds. the tint is either
Bad news is the light engine failed. Good new is Sony extended all warentys for this model till June 2010 so get this to the shop, you do not want to pay for this $800.00 light engine
Dec 29, 2009 | Sony KDF42E2000 42" HDTV
Tv screen turned blank but there is sound
If you are running normal rca (red, yellow, white) for your reception try fiddling with the yellow one. this is your video feed. If they are component cables (red, blue, green, red, white) make sure that the reds arent mixed up and if its and hdmi cable it may just be faulty. Try replacing it. hope this helps
Oct 01, 2009 | Philips 42PF9630A 42 in. Plasma Television
Red tint while using component cables
Disconnect component cable while observing screen, just to make sure that is your problem. If it is and you already substituted the dvd player and it still happens,, try replacing the cable, it may be defective. If it still happens there may be some kind of a processing defect with the component input of your tv, why not just return to RCA's
Aug 07, 2009 | Toshiba 27AF45 27" TV
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Oct 15, 2006 | RCA F27628 27" TV
RCA F27648 27" TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
