Question about GE APH10AA Air Conditioner
My GE AEQ10AMG1 air condition is showing ep in the display and is not cooling properly
Last night I turned on my ac and EP showed in the display, i tried turning off the ac and using the reset button a few times, it cleared once and 32 showed in the display but 1 minute later the EP was back
What does error code EP
you should be able to clear the code by removing the battery, and by the way does it have new good batteries?
Nov 17, 2015 | Walgreens By HoMedics Automatic Wrist...
Ge air conditioner error code ep
GE EP code is main compressor sensor.
Check damage to the temperature sensor
Sensor Cable left side yellow.
My airco got visited by a rat and damaged the wiring.
Cut it rejoined and code 32 changed into temperature.
You need the sensor. Just joining the cables will issue 99 and it will cut off and change into 32
You need a working sensor.
Apr 23, 2013 | Heating & Cooling
My ge AEW18DMG1 window unit shows an error code EP. What does it mean?
Jun 01, 2012 | GE Air Conditioner Main PCB - WJ26X10241
Just purchased a used HP LaserJet 4 Plus -- when turned on and installed it is showing 14 no EP CART -- we do not use cartridges so need to reset to default settings. Tried Power On and holding online but...
Ensure that the Toner Cartridge is installed correctly (fully
seated into the printer). Try a new Toner Cartridge. If the
problem continues, try this
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 Reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller.
Jul 05, 2011 | Office Equipment & Supplies
I have an GE air conditioner with ''EP error code, and compressor stops.
Jul 01, 2010 | GE Heating & Cooling
What does EP mean on the air conditioner display?
I had this same problem with mine, i unplugged it and pushed the reset button on the side and now it's working fine.
Aug 25, 2009 | GE Heating & Cooling
EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Jul 27, 2009 | GE Heating & Cooling
Honeywell chronotherm III air conditoner
I had that last night. I turned off the unit for a couple of hours and it came back on and ran and cooled. I have no friggin' idea if it will work but it got us through last night.
Jun 05, 2008 | Honeywell Power Humidifier: Furnace...
GE APH10AA Air Conditioner Logo
46 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
