Behringer mx8000 i have a 7 pins power connector and want to know on wich pin witch voltage , i know it is 18/-18/48/12/5 but i do not know where
    New Friend:
  • 151 Answers
Is your supply gone ? difficult. check inside, you can see what leads feed what regulators, I hope. However, hard to build a supply with all them voltages... get a new one, I suggest. Luck...
Posted on Apr 27, 2014
I have lost all my wires to my Bunker Hill security camera item 95914 how can I make some more
Hi Jeff
It looks like the camera use an RJ 45 Plug to transfer the signal and power to the AV and power plug connectors. All you have to figure out is which pin goes where.
Power uses 2 pins, Video uses 2 pins and Audio Uses 2 Pins.
So you can get a network cable with an RJ45 connector at the end and connect the AV and power plugs on the other end. I just dont know which pins are witch.
Jan 28, 2017 | Computers & Internet
How to connect the raidmax rx-730ss power supply to the gigabyte ga-z97x-gaming 3 (rev.1.0) motherboards 'ATX_12V_2X4' port?
The 2 plugs are seaparte because many mainboards do not have the 8-pin CPU power plug. Use the second 4-pin on the side of the connector.
Aug 02, 2014 | Gigabyte Computers & Internet
Sorry, I mean, I have a sm 57 connected to a behringer ultragraph fbq1502, then to a behringer multicom proxlmdx4600 and then to a behringer xenyx 2442FX, and works very well
First try another cable. Then one more. Then take a mufti-meter and test the mic cable pins to see if you are actually getting those +15 to +48 phantom volts. On Balanced XLR connectors Pin 1 is ground/shield. Pin 2 is HOT. Pin 3 is cold. Measure pin 2 positive and Pin 1 to ground at the mic end of cable. See if you are actually are getting phantom. Balanced TRS connector is tip hot, ring cold, sleeve ground. You should always have a couple of digital multi-meters with audible conductance testing for all connections, and good batteries on hand when working with studio equipment. It saves a lot of headaches such as a bad cable. Even a brand new one could be bad! After eliminating cables...I tear the mixer apart. I know it may be too much but, when I Engineer a new studio for someone I make sure all cables are out of the way and cut and soldered to the length of each cables designation. That way they are all out of the way and they never get the chance to go bad. Also save time by setting up your studio so everything is mostly a permanent installation, that way you do not have to keep re-connecting things. Only a new piece of gear once in a while. Good luck!
rockinbadboy-
Sep 02, 2012 | Behringer Music
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
What is voltage pin layout for the connectors on power supply model dr-b300atx
I assume you are talking of the 20 or 24 pin connector plugging into the Motherboard. Is it 20 or 24? Is there a 4 pin +12v connector plug. The colors of the wires tell a story. Red is +5V Black is Ground or Return. There is Yellow and Orange and Blue and green and gray. There are SATA connections . Look in your users manual of a standard Motherboard. This will give you a pinout and voltages on these pins. Write down the voltage starting with pin 1 and add the color to simplify knowing the voltages. If you're tech savvy, break out a multimeter for absolute certainty.
Mar 26, 2010 | Austin Computers & Internet
I am looking for a power connector wiring diagram for the Behringer Eurodesk MX3282A? It was rewired by someone and I think the wire combination is mixed up because when plugged in it seems to blow...
Some of the mixers have common connectors.
It appears that for the three pin connector, pin 2 is center tap of AC source, and pins 1 and 3 are the ends of the transformer windings.
This is from a schematic of a MX2643A which MAY be similar to yours. One of mine has a 3 pin Amphenol connector with a locking screw ring...
Use this info at your own risk, however, the power inout is easy to trace out to verify. They use a typical bridge rectifier to get plus and minus from the external transformer.
The pin markings on the connector CAN be confusing.
Suggest you use the light bulb trick of putting a small lamp in series with the 120 line as an auto reseting fuse.
Mar 03, 2010 | Behringer Music
Telex 56 to cobra 4 pin
Hi there!!
the yellw wire is not used on the microphone conector most of them are just cut and left in there loose as long as its not shorting out on anything!! The wiring for the telex 56 for your radio Cobra 29 LTD is as follows: PIN #1 Shield & Red, PIN #2 White, PIN #3 Blue, PIN #4 Black, Yellow wire not connected!!
If you notice when you have the connector apart on the back of the pins where the wires get soldered to the pins are numbered so you will know which pins they are or on the front side of the connector the pins are also marked wich numbers they are!! If you have any other questions please feel free to e-mail us at: bigdscbshop@hughes.net
Apr 18, 2009 | Telex M-560 Consumer Microphone
Replace 4 pin plug on Behringer V-Amp2 PSU
Hi mgriff66
I have scoured the net to get the info you need, but came up empty handed. I would take the back off the unit and work out what connections are what from tracing it out to the power supply. If you are not up with electronics, then that may not be an option. I have emailed (ref 080528-000007) my Behringer contact to get the info for you. Will post it back here shortly.
regards
robotek
May 26, 2008 | Audio Players & Recorders
CTX Panoview 630 Monitor
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
1pm:NC
3pm:+12
5pm: no pin
7pm:+5V
9pm:+5V
11pm:GND
shield is GND
+5V@3A
+12V@1.5A
(you can modify an Apple ADB cable to work)
Mar 15, 2007 | CTX Panoview 630 Monitor
93 people viewed this question
 Grubhead
Grubhead
