Question about Philips Magnavox 51MP392H Rear Projection Television
I have a 60" Philips 9P6044 C104 rear projection tv. The color seems to be getting weak and the colors seem to blend together. We think we may need new bulbs, but we dont know how to change them out. Is it the bulbs, if so how do we change them, or is it something else?
  • Philips Master
  • 8,617 Answers
Its actually the collant in the CRts that makes the picture appear dim with colors being faded and hard to focus. You can get the CRT coolant kit at the following link which contains the coolant for all three CRTs and the CD with instructions on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Posted on Jun 15, 2009
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
The color has changed to everything is tinted yellow or greenish have tried to adjust with remote, but no help
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
43'' HD projection philips tv color change
Check on ur auto covergence.Might have magnatics interference,the tv tech.use a dequasing coil to solve this prob.when it very bad,colors mast together.
Sep 12, 2009 | Philips 43PP9202 43" Rear Projection...
Cloudy screen/
More than Likely your Tubes are getting weak!, (3 tubes - Red, Blue, Green) Need Replacing or Rebuilding (fluid change). g.
Jun 26, 2008 | Philips 60PP9202 60" Rear Projection...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Color on projection tv 9P6040-C104
The cooling fluid in the CRT's need to be replaced. This is a common issue with NAP projection TV's. The old fluid needs to be drained then the CRT faces cleaned then refill with new fluid.
Jan 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
232 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
