Question about Midland Radio MIDLAND HH54VP2 Handheld Weather Alert Radio
My just purchased HH54-2, battery icon does not show-blink -"Charging" & only displays 1 power bar. What's up with it !!?
All other functions seem to be working - have received 2 Weather channel checks via alphanumeric readout. Radio is set for Voice Alert.
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Battery light dosent work during charging or fully charged. Light comes up at times. battery level is either not indicated properly
In most models the battery light is displayed when it is charging with a possible blinking when it nears charging and it cuts off when the charge is full.
So if your laptop shows that the battery is charging in the task bar- bottom right, then you can ignore the issue unless your laptop is in warranty and it can be done free of cost.
If you open power options in the control panel the charging will be displayed , if this show Ok then the fault is the hardware circuit issue on the mother board power section.
Jan 22, 2011 | Computers & Internet
My computer wont charge..could it be the power cord or the computer battery?
If the laptop is old think about changing the battery.
Stelios.
Feb 22, 2010 | Computers & Internet
MY Zen WONT TURN ON. It also wont charge.
Connect the player to a USB port on the back of a desktop PC.. Check the display for the charging icon . As the display times out after a few seconds, press any button on the player to reactivate the display. If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging. If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality.
http://support.creative.com
Jan 16, 2010 | Creative Labs Zen Micro MP3 Player
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Unable to charge
you need a new batt.
go to any local phone store to get one.
Jan 18, 2009 | Motorola Mobility RAZR V3
My player wont turn on. The computer reconizes it for a couple seconds but then the player shuts down. The play/pause button blinks but the olayer doesn't seem to be charging. The reset button is broken....
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Creative recommends updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Creative Labs ZEN V Plus MP3 Player
My Zen v plus won't turn on. The reset button is broken and it will have the play/ pause button blinking but it doesnt seem to be charging. The computer reconizes it for a couple seconds but then the...
    • If the battery is fully depleted, the charging icon may not be displayed.Cup the player in your hands to check that the blue power LED behindthe Play/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
Ifthe player does not indicate a charge, or will not power on after atleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to take advantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Trouble
Hope this helps
Chris (ziraffa)
Jan 06, 2009 | Creative Labs ZEN V Plus MP3 Player
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Midland Radio MIDLAND HH54VP2 Handheld Weather Alert Radio Logo
43 people viewed this question
Top Midland Radio Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Midland Radio Measuring Tool and Sensor Expert? Answer questions, earn points and help others
