Question about Kenmore Intuition Upright Bagged Vacuum Cleaner
Brush wheel not spinning
Beltless not spinning
  • Kenmore Master
  • 4,006 Answers
It can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Posted on Apr 03, 2014
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
My panasonic canister vacuum agitator brush does not spin when on
Possible that you did not get the belt on properly and came off right away.
Apr 13, 2014 | Panasonic MC-CG917 Canister Vacuum Cleaner
The belt won't stay on! I put it onto the silver piece that spins...as soon as I turn it on to test it it comes off...the brush doesn't spin...Am I missing a part??
Cathy
The brush roller only sits one way and must b free rotating not jammed up if roller is tight to turn disassemble and clean it when u put it back after u have put belt on turn by hand to see if it stays on, if it does ok done .
Cathy theirs ,
only to things that will cause this the brush roller running out of square, or jammed up and makes the belt jump of.
Oct 18, 2013 | Dirt Devil 0100 Handheld Bagless Vacuum...
No air
The bushings need regular lubrication with silicone spray.
May 29, 2012 | Oreck Air Purifiers
I have an Oreck XL that is very noisey, even on the silent run position. How can I gegt it fixed?
The problem may be build-up on the blower wheel. When the Truman cell cover is removed, two screws are visible which secure the cover for the blower. remove them and the cover hinges. Keep opening and it will unhook. Use a stiff brush to remove soil from the blower wheel. The unit can be turned upside down over a trash can or better still, outdoors to remove the excess.
May 27, 2012 | Oreck XL® Air Purifier
Pure pro fan motor
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
How to remove air filter for cleaning
If you are talking about the metal wheel inside, the only way I have been able to clean it completely is to turn it over, unscrew all the screws, carefully lift it apart, and then you can lift the wheel out. But after you clean it, make sure its completely dry . I usually leave it out in the sun so it drys completely. Then while its out, you can either take a can of the air, like you use to clean computers, or if you have a vac that you can blow air from, or just simply use a soft cloth, brush, whatever you have that can clean it. `its a pain to do, because they def don't mention about how dirty it gets inside there, but honestly I love my purifiers so much, even though its a pain to do, I do it anyway! hope this helps you out alittle!!!
Nov 13, 2010 | Oreck XL Professional Air Purifier
Sparks shooting down sides of ozone plates
Disconnect the power and give it a good cleaning with a SOFT BRISTLE PAINT BRUSH. Outside is best. Blow it out gently with canned air after you brush the dirt loose.
Jul 25, 2009 | Ecoquest Flair Air Purifier
I was just wondering if the fragrances contain oil in them?
You simply remove the spindle and wash it out, and the spin wheel too if ot gets a build up. I use an antiseptic sort of smelling scent in mine and it helps capture dust. That is part of the build uop on the spindle. Simply turn it on the spin wheel and remove it and then wash it under hot water and let the hot water course through the spindle to clean it out.
Feb 09, 2009 | Rainbow Rainmate Air Purifier
Water wheels do not turn
Unplug the unit from the A/C outlet.  Turn the fan unit over, and with your finger, spin the fan as fast as you easily can.  Tooth like projections should rotate out of the lower most part of the assembly.  These teeth drive the wheel.  If they don't come out, the problem might be in the seating of that silicon rubber nipple, or the "tooth" assembly could be gummed up with algae and deposits.  You can wash it out.  The problem with mine is the teeth work, but the wheel still doesn't move.  I have emailed the sales office for help.  I love the unit's performance, but it is temperamental.  Good luck, and please post, if you fix it.
Feb 26, 2008 | Venta Airwasher Venta LW14 180sq ft...
Kenmore Intuition Upright Bagged Vacuum Cleaner Logo
Top Kenmore Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
