Question about Akai ks-808 professional karaoke system with speaker pe
TFT no coming on
The TFT screen is not coming on
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - β€Ž58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - β€Ž18 votes - β€Ž$59.78 - β€ŽIn stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
Aug 06, 2015 | HP L1908W 19" LCD Monitor
There is horizontal line come in TFT in last 2 yr i ask the dealer he told that its bcoz some resister short now after another line come in my TFT whats the problem? and notice that this problem come after...
You may have failing TFT (Thin Film Transistor, each pixel on the screen is driven by one transistor, so there are 100 of thousands on the LCD panel
) or bad connection or failing T-CON board.
See pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
It will usually get worst with more lines as time goes by. New panel will be needed.
Jun 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
How to find hidden controlls on my jensen
Real easy. Put in a cd, hit setup on your remote. When the setup screen shows up, pressz 5,4,3,2,1,0 should come up with hiddend display to change DVD region Codes, Bypass your Parking Brake lock, and tft screen test (don't use tft screen test) it's a pain in the arse to shut it off.
Apr 18, 2010 | Jensen's VM9312 Car DVD Player
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
My monitor will not come on...it is a Gatway TFT
i u can try another pc to Monitor....also disconnect and and reinstall monitor cable
Jun 27, 2009 | Computers & Internet
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
DUAL XDVD8181 car unit - motorized TFT screen won't come out!
Open it again and check the ribbon cable for cracks, the one that get drag in and out every time it open and close. Because it is a defect for Pioneer too, and Pioneer would replace it free. Goodluck.
Mar 01, 2008 | Dual XDVD8181 Car Video Player
TFT Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Akai ks-808 professional karaoke system with speaker pe Logo
75 people viewed this question
Top Akai Audio Players & Recorders Experts
Michael Harrier
andrewcahoon
 Grubhead
Grubhead
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
