Question about Akai ks-808 professional karaoke system with speaker pe
The screen TFTit not coming on for the Akia KS-808, how do we fix it?
Power is up but the TFT is not coming on
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
Akia pt 4298hd
Look on power supply AC board themostai coupler most of the time has Poor solder connections resolder it.
May 08, 2010 | Akai PT4298HD Rear Projection Television
I have an Akia TV DTV1080i and can't solve the color convergence as can't get the red and blue + to come together what should I try
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
3b59090.pngYou can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Televison & Video
Tv won't come on
Did you get this fixed yet?Please let me know.Thank You very much!
Tyler
May 31, 2009 | Akai LCT2662 Television
Dell Monitor 1907FPt comes on for a short time and goes to a black screen. Power light is still on. How do I fix this?
HI
YOUR PROBLEM IS NOT INVERTER BOARD IT IS MOST LIKELY THE LAMPS, ANY 19" LCD LAMP THAT FITS WILL FIX IT FOR YOU.
THANKS
AHMAD
Mar 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Ds-1107a inverter/power supply no power or comes on &LCDflickers
Classic sign of bad inverter. Since it is inside the LCD not something you can fix yourself unless you work with electronics. Needs to go to the repair shop.
Jan 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
AKIA LCT42Z6TM
You have the same problem that most people that have this unit do. I had the same problem and fixed it. can fix this, as I have fixed 4 of these units already. Email me if you want more info tommy@ruden1.com
Jul 09, 2008 | Akai LCT4216 42 in. LCD Television
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Akai ks-808 professional karaoke system with speaker pe Logo
82 people viewed this question
Top Akai Audio Players & Recorders Experts
Michael Harrier
andrewcahoon
 Grubhead
Grubhead
Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
