Question about MGE Computers & Internet
I need the pin configuration of Battery detection cable for MGE UPS EX7RT
It is like a network cable with RJ45 connectors. but i don't know the pin configuration of it.
  • MGE Master
  • 3,320 Answers
Here's a link to the manual.
An RJ 45 network connector will either be a crossover or a straight patch cable. http://www.mgemexico.com/pdf/EX_RT_manual.pdf
Posted on Mar 29, 2014
4 Suggested Answers
  • 21 Answers
SOURCE: UPS MGE problem
  1. old school hollywood baseball old school hollywood baseball old school hollywood baseball
  2. old school hollywood baseball old school hollywood baseball
  3. old school hollywood baseball old school hollywood baseball
  4. v
Posted on Feb 10, 2009
micromatikal
  • 2777 Answers
SOURCE: How i can add additional
I am a bit confused by your question here. You say you want to run two of these units in tandem, one into the other, correct? And are both MGE 2200 models? Let me know some more info and I can help.
Thanks
Tim
Posted on Sep 29, 2010
  • 352 Answers
SOURCE: MGE EX7RT showing fan fault
Hello.
This fault is due to the cooling fan not operating at the correct speed or not at all.
It is a simple removal to replace it, remove the outer case and the fan. The fan is available from any electronics or computer store and I would recommend taking the fan with you to obtain the correct type.
If you are uncomfortable replacing the fan then any one who builds computers will be able to assist you.
If you notice that the unit seems to be running hot then switch it off, otherwise if you keep the unit in a cool area then it should not be a problem.
Regards GM
Posted on Jul 28, 2011
Hi How many batteries installed in mge galaxy 3000
Configurations vary, do you have a model number you can provide?
If you need any UPS help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website
www.psihq.com
Sep 17, 2013 | MGE Galaxy 3000 UPS System
MGE UPS Tuner softwares
My dear i think there need to upgrad/re-initialized its battery life from ups tuner.
i have mge ups tuners for all models
Regards
techdata41@gmail.com
Jul 28, 2012 | MGE Galaxy 3000 UPS System
MGE Galaxy 3000 UPS, do i require to reconfigure the ups after battery replacement? Thanks.
No you don't have to reconfigure the UPS after battery replacement. However you may have to reset the battery Timer. There are 4 possible ways.
1. Press and hold the fault reset button for 3-5 seconds
2. Press and hold the fault reset and security key simultaneously for 3-5 seconds
3. Press an dhold the fault and alarm silence buttons simultaneously for 3-5 seconds
4. Cycle the logic Power. This means to remove power from the main processor.
5. Call MGE. They have the software to reset the battery replacement alarm
Oct 19, 2011 | MGE Galaxy 3000 UPS System
I have mge galaxy 3000 single unit 30 kv who shown those messages: defaut refroidissemt defaut temp batterie thank you for you help
sounds like you have a battery in thermal runaway. That means your battery could catch fire. I don't know what refroidissemt is. Your spelling is wrong. Go back to the UPS and write down the right alarms. Then I can help you.
Sep 24, 2011 | MGE Galaxy 3000 UPS System
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
higher).
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
Please clarify that, MGE Galaxy 3000 will produce Harmonics.We had few issues due to harmonics which is affecting Analog modules connected with UPS supply. How to detect and filter harmonics at UPS.
The galaxy 3000 does not produce a huge amount of harmonics that are reflected into your building. I use an AEMC Power Pad, or a Fluke 434 to measure the harmonics on the input power cables feeding the UPS while it is on. Fluke also makes a nice clamp on harmonics meter (AEMC had a nice one, but it was discontinued)
Feb 10, 2010 | MGE Galaxy 3000 UPS System
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Sep 30, 2008 | Digi (76000200)
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
UPS not charging
Sir, Our UPS is not charging at all. After following the procedure for shuting and starting up, it show battery charging 0%. The model is MGE Galaxy 3000 UPS and also cooling fan is going to falt mode .with best regards
Jul 02, 2008 | MGE Galaxy 3000 UPS System
Computers & Internet Logo
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
