Question about Frigidaire FFBD2411NS
Dishwasher won't drain
I ran the dishwasher and it sounded like it was working fine. When I went to empty it, I found a pool of white water at the bottom of the machine. How can I fix this?
  • Official Brand Answer
  • 2,267 Answers
Good Morning Jean,
I see that you are having trouble with your Frigidaire dishwasher, model# FFBD2411NS, draining. There are a few things I would suggest:
1) If the appliance is hooked up to a food waste disposer, make
sure the disposer is empty.
2) Check to see if the knockout plug has been removed
from inside the food waste disposer inlet.
3) Check to see if drain hose is kinked.
4) Check the glass trap filter to see if anything is preventing the water from draining.
5) Overfill Protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean occasionally with
household cleaner containing vinegar or bleach to dissolve any buildup.
If none of these suggestions help your dishwasher to drain the water, I suggest contacting your local authorized technician.
-Best Regards-
WP
Posted on Apr 04, 2014
Skill Will
  • 53 Answers
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
SOURCE: dishwasher not draining
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Jerry
Posted on Oct 18, 2008
localwonder
  • 6784 Answers
SOURCE: dishwasher not draining and making a noise
Ok, normally, when you hear abnormal noises and the draining has stopped, this will point to the pump/motor assembly. this assembly , basically, runs together in unison. the pump/motor are as one and if the motor is malfunctioning, the pump will not drain properly. this noise is coming from the pump housing. There are many parts that are located in this housing and one fragile part that can cause issues is the Impeller. this piece provides the pump action that moves the water during drainage. If the sleeve that connects to the Impeller becomes stripped, the motor drive bolt will simple spin freely, causing this noise and no drainage. The motors fine but, you will have to replace the pump assembly in order for this noise to stop and the normal draining cycle to return. just to be safe, check all the drainage hoses as well.
please rate and god bless:)
Posted on Apr 01, 2009
SolutionGuy
  • 331 Answers
SOURCE: KitchenAid Dishwasher fill up with water after use
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
Posted on Apr 14, 2009
SOURCE: The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
I INSTALLED A NEW GARBAGE DISPOSER AND THEN FOUND THAT THE DISHWASHER WOULD NOT DRAIN. READ THAT THERE WAS A SEAL IN THE NOZZLE OF THE GARBAGE DISPOSER THAT HAS TO BE REMOVED IF IT IS ATTACHED TO A DISHWASHER. I DISCONNECTED THE HOSE,WITHOUT REMOVING THE GARBAGE DISPOSER, PLACED A SCREWDRIVER IN THE HOLE AND HIT IT WITH A HAMMER AND KNOCKED IT OUT. REPLACED THE HOSE AND TIGHTENED THE RING AROUND THE HOSE. TURNED THE DISWASHER TO DRAIN AND IT WORKED PERFECTLY. MY MISTAKE FOR NOT READING THE DIRECTIONS THOROUGHLY. ALL IS WORKING WELL; HOPE THE SAME FOR YOU.
Posted on Jun 21, 2010
Belling dishwasher won't empty. I have cleaned the water filter and the machine worked fine this evening it won't empty?
Search Results
    Belling won t drain Dishwashers Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > won t drain > Dishwashers
    Belling dishwashers won t drain related questions and answers. Ask your Belling questions. Get free help from dishwasher experts.
    How to fix a dishwasher that won't drain - Dishwashers ...
    www.which.co.uk/.../dishwashers/.../how-to-fix-a-dishwasher-tha...
    Which?A dishwasher that doesn't drain can cause concern in your kitchen, but you may not ... Check out our video to see how to repair a dishwasher that won't drain.
    i have belling dishwaher which is not emptying e1 showing as
    www.justanswer.co.uk > Appliance
    OK, so it fills and starts the cycle and then won't drain and this error will flash ... is ... the washing machine which is at the side of the dishwasher has been giving ...
    How to Fix a Dishwasher That Will Not Drain - YouTube
    ? 2:13
    https://www.youtube.com/watch?v=nr6tIO5iNSc
Feb 08, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Water pooling on bottom of dishwasher
Check the drain pump for debris that might be stopping the drain pump from working. Also could be faulty drain pump.
Feb 20, 2009 | GE 24 in. GSD4320Z Built-in Dishwasher
We have just installed GE Model GLDL560NSS. It fills with water and it emptys the water but it doesn't actually wash or rinse. The water just sits at the bottom of the dishwasher tub
I had the same problem running the dishwasher the second time. The first time worked perfectly. I thought the problem was from the sensor not reading enough water to actually start the wash cycle. It sure uses less than any dishwasher I've had before. When I tried to restart it the machine drained the water that was in it. I later found out it does this automatically when you push the restart button. I poured water from a bucket into the dishwasher and tried this a few times and found that on the fourth try it ran fine and haven't had a problem since. I didn't know how much to put in and did overfill it once. Maybe the sensor float or whatever was stuck and overfilling it helped.???
Jul 23, 2008 | GE Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Problem with my dishwasher not draining at all.....
Has this Dishwasher ever drained at all? In installations the need to have a drain line attached to a disposal system is top on the list, how ever some times the connection is made but a small plug in the disposal on the inside of the wall of the grinding chamber has to be knocked out to allow for proper draining of the dishwasher water.
Aug 20, 2007 | GE PDW8200NWW / PDW8200NBB Dishwasher
Frigidaire FFBD2411NS Logo
277 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
